Updated Pics 10-9-06 1973 Fj
Well finally finished the roll cage, sliders and seat mounting system. The install was a PITA becasue there were so many pieces. As shown we tied the cage into the frame. The rear was cake to tie in compared to the front.
The front frame to chassie mount had to be incorporated into the sliders becasue of clearance problems. Nonetheless it was finished. The seat are awesome and the positioning is perfect.
:cheers: :cheers: you did a great job on the mounting it to the frame . I mounted mine with shackle bushings to the frame. to keep vibration down off the floor pan. still very nise work! What kind of seats are those.
I wish I could say I did the welding, but I had it professionally done. However, I did get to help with the tacking and some of the notching. Had a good time doing it.
The seats are the Mastercraft Baja RS (built in suspension). They're very comfy and very well built. Worth the money, IMHO. Haven't been road tested however.
Here's a pic of the cruiser when I first started.
in the botom pic, on the front seat cross bar, Is that a Tab welded or, a but joint seam, I cant tell.
It's a butt joint seam.
On another note. I took the cage to the powder coater today and it's only $200.00 to powder coat and clear. I haven't chosen the color yet, but I'm thinking with going black with a cracked silver pewter undertone.
that is money, thats on my wish list, can you give ame a breakdown of cost minus the labor
seats
cage
i love those seats. does the cage come with the seat brakets?
seats
cage
Seats with all mount brackets, sliders and tilt and lumbar adjustments $1,300.
Roll Cage, sliders, and seat mounting system from Mark at Metal Tech: $1,200.
The seat mounting system (gas tank consideration) ordered from Metal Tech had to be modified to fit our application. We tried many different angles but couldn't get it to fit properly without cutting the tub wheel wells becasue of the gas tank. Now I have to buy a rear tank.
However, we did use the pieces, cut'em down and fabricated the rest from additional materials I purchased.
The seat mounting system provided by Metal Tech does have a mounting system for the seat bolt holes. Esentially they are (brackets) water jet cut from flat steel. They're very nice.
All and All I like the finished product.
:cheers: Nice Job...Can you put your jumpseats in now? I'd like to install this cage in mine...but want to keep my long jump seats...I may have to make my own cage, and offset between seats and hardtop...
I'm not sure about the jump seats. The PO had a bus seat in the back facing the opposite direction. I don't think I'll put jump seats in. The bed will be for my doggies..
