ARCHIVE 80 Series Body Lift Kits
Portland, OR
www.duiser.com
1" and 2" Body Lift Kits for the 80 Series Land Cruiser FJ80 FZJ80
The only COMPLETE FJ80 AND FZJ80 body lift kit available, from the hardware, pucks, DROP BRACKETS. We include everything you would usually pay more for;
  • Heavy Duty Standard Hardware, standard grade is stronger and cheaper.
  • Rust free polyurethane pucks
  • Black Pucks, because who wants bright white pucks under their truck!!??
  • One aluminum puck for near exhaust
  • Large pucks for greater contact surface area
  • Aluminum extensions for 2" kits (steering and shifter)
  • Annnnd RADIATOR DROP BRACKETS!!
Written instructions are provided, instructional step by step video coming soon!!!
1" Body Lift Complete Kit $130.00 Plus shipping Approx $10.00
2" Body Lift Complete Kit $230.00 Plus shipping Approx $10.00
Buy at;
www.duiser.com
For Questions Contact;
sales@duiser.com
Which body lift kit is right for you?? 1" or a 2"??
Body Lift Video;
See this link for a little write up;
https://forum.ih8mud.com/80-series-tech/653439-body-lifts-love-them-hate-them.html
The 1" is super easy, you loosen the opposite side of the body mount attachment points while you install the other. If your vehicle is rust free its a quick and easy 2-3hr job. This will allow you to fit bigger tires and or have more articulation without rubbing.
Ideal for 35" tires, stock suspensions, or a lot of flex if you have say 33" tires.
The 2" lift is the same except you will have to install the shifter and steering extensions and lower your radiator. Its a bit more work but, if its flex/ articulation/ max tire size you are after the 2" is the way to go. This job may take an afternoon. Get a friend to help! The extra 2" will achieve a noticeable lift and provide you A LOT more articulation without rubbing.
Ideal for 35" tires and up, rock crawling, maximum articulation, etc.
The kits come with instructions. All you need is a socket set and a jack. You will need a drill if you get the 2" lift in order to lower your radiator.
We also make;
URB's
https://forum.ih8mud.com/merchandise-storefront/634825-universal-recovery-brackets-urbs.html
:cheers:
Pictures show 1" and 2" BL kits
Sorry for the picture delay, see 1" Body Lift Kit Picture
I made a few changes to the kit description. The kit no longer includes metric hardware. Why?? Because the standard hardware is stronger and cheaper, its a WIN/WIN.
The kit also includes radiator drop brackets. Previously we had instructions on how to drop your radiator, now we give you brackets to do so. Super clean, super easy, same price!!
2" Body Lift Kit is coming, waiting on shifter extensions. It also includes steering extensions and radiator brackets. Very clean. :cheers:
Yes, there is a 1" increase between the bumpers and body that is visible. You'd be hard pressed to notice though. The 2" lift is noticeable.
Search on MUD to find examples.
any pics of 80's setup with a body lift? curious to see what it looks like and if there is a gap showing when the 80's are lifted one inch.
2" Body Lift Kit Picture!!!
As you can see, a steering shaft and transfer case extension is included. All pucks and radiator drop brackets are 2" BODY LIFT specific.
We offer the ONLY complete FJ80, FZJ80 body lift kit available!
$200.00 Plus Shipping
:cheers:
