I have been doing some searching on installing 14 bolt axles in Land Cruisers. The cost of going to a centered rear 14 bolt and dana 60 front with a NP205 adapted to my NP203 all at the same time seems kind of steep. My SOA FJ60 is road legal and I use it for weekend fun trips and for transportation to work when the snow is to deep for my Honda Civic.
Here is some information on my existing setup.
-85 FJ60 SOA on stock springs and 37" tires on FJ80 16" wheels and 2" wheel spacers.
-383 V8 / 700R4 / NP203 / Toyota split xfer case
-Front axle is Long Field 30 spline with hub gears / ARP steering studs / ARP hub studs / 4X4 Labs steering / ram assist.
-Stock rear FJ60 axle that has broken the short side shaft twice.
Seems like a 14 bolt will fix the rear so I am thinking of modifying a 14 bolt from SRW (67" WMS-WMS) to use two short side axle shafts to I end up with a 61" WMS-WMS off set axle.
I think I will be working my way towards 4d's so at some point I may want to run a dana 60 on the front so I don't know if I should convert the 14 bolt to 6 on 5.5 or just run 8 lug rears and 6 lug fronts for now.
Now for questions......
1) I assume someone is running a modified 14 bolt with two short side shafts so has any of these people had problems with this setup?
2) Would it be better to modify a C&C 63" 14 bolt to end up with the correct Toyota TC alignment. and find 8 lug wheels with more back spacing to align the front and rear wheels?
3) Will the FJ60 split xfer case hold up to 4d's?
