the window placement has alot to be desired on their new top IMO more so than the price
Alil soap on the channel and rubber it will slide thru nicely...if you use a lube like spray sylicone...if it gets on the canvas it will be there for a long time...like getting a oil stain on your jeans.
if you look at the top corners of the door the metal of the channel is bent in (alil angle piece) bend those out on the front side and rear side on the top of the door...and thats where the weatherstripping will feed in...then when the stripping is all in trim the weatherstripping and bend the tabs back in to lock the weathersripping in place
https://forum.ih8mud.com/40-55-series-tech/282091-rebuilding-factory-soft-doors.html
https://forum.ih8mud.com/40-55-series-tech/98570-oem-canvas-doors-finally-done.html
Also Johnny...
How did you go about stretching the canvas evenly for the doors?
Did you glue it in before mounting the channel so it would remain tight/ taut >?
If you have any insight, or even photos documenting it i would be grateful
I remember you mentioning that there was an article in toyota trails about it, but i have not been able to find the issue![]()
