Feeler for Sub bracket Group-Buy
I am recently new to the 80 platform and excited about new parts and designs, so prepare for lots of new gear.
While writing my build thread I had mentioned that my girl had bought some sound gear and a 10" sub. I am NOT for boxes, so set out for a solution. I stated my idea and was asked to build it as a 10" didn't exist, so here it is.
This is for a head count on a small run of these.
-Speaker bracket that holds a 10" subwoofer shallow mount Free-Air
-9.25" opening, I search and search and this was the largest I had found, you must very.
-Will ship with foam block to isolate speaker from harmonics by isolating speaker and body panel.
-14ga galvanized steel for corrosion resistance and strength.
-Direct bolt in like OEM
The only change I may make is to drop a tab down 4" to attach a fuse block as we are looking for a place that is out of the way.
Will be under $100 ($80 if enough want it) shipped to your door, $16.00 is flat rate shipping USPS Priority
I recently purchased an 80 and began our build thread and will be offering some great parts for them.
-I see a need for a split platform in the rear. Using existing mounting locations for attachment. Why split? Many use fridges, dog kennels, pelican cases or want 1 3rd row seat intact.
-Speaker brackets where the 3rd row seat belts are bolted in the pillars, will hold a 4" speaker
-3rd row seat striker plates (remove your strikers and hardware) 4 total for the rear floor.
-Reverse camera/Light mount (for us that don't want to cut holes in the body of have bumpers in the way and hate exposed wiring)
-Replacement grille that will hold a 14" light bar THREAD STARTED
-Front winch plate
Any need for the above? if so, I will post up and see what I can do.
See my build thread for photo's.
Thanks,
Shane
-Front winch plate
Thanks,
Shane
