Slipping upon takeoff
Northern Territory Outback Australia
A little while ago I did my viscous coupler in the transfer case, pulled it completely and now I seem to have some sort of slip sometimes when I take off at the lights. I think it could be the slip yokes, maybe? they have been regreased recently so are not bone dry or anything. What do you guys suggest checking?
By 'slip' I mean drive isn't continuous, there is something slipping for a very brief moment just after taking off, unless I gas it hard and then it doesn't happen.
Adjust cables ??
The transmission throttle cable. You might want to check the fluid level and colour too. Should be on the full mark with the engine running. It should also be a cherry red colour, and have a sweet smell. If it's brown/black or smells a bit nasty then it would be a good idea to drop the pan and change the filter (and the oil)
Hmmm, thanks fellas.
I have no idea where that might be or what to look for but I guessI'll learn. Will take a look in my service manual and check it out. I'm not sure what to look for once I find it but I guess I'll figure that out too
Thanks guys.
X2 with regards to the fluid check... I would start there and be sure to check according to proper procedure (fluid hot/warmed up, level surface while checking and engine running); search the board for numerous posts...
I dunno about the trans of the 80s - they seem to last for a long time... But when I had slipping in three previous 4x4s - (Exploder, 99 and 02 Tahoes) it was a sign that the tranny was going out and needed a rebuild. Could that the case here?
^^ No.
Hey all!
I still haven't looked at the truck yet but have just revisited because it's still there. Need to gice it a service soon too (too busy this weekend so will have to wait until next) but will check all these things mentioned
Cheers
Well whaddya' know I took a quick squizz at this last night and the trans oil still smells and looks good and is actually a tadd over the hot Full mark, always has been, I haven't changed it in 45,000kms
The throttle cable connection does have a bit of play in it before it does anything, so what I mean is; I can pull the cable with my fingers about 1/2 of a cm before it actualls pulls. It's loose until then. You reckon this will be it?
Ok, I serviced the truck with new engine oil over the weekend (still haven't done my trans oil or filter..), and ever since then I haven't noticed this problem anymore.. The dipstick was showing "F" but I only got 5.5-6l out of the drain.. I put about 7.6 litres back in and now things are good.
I don't understand why this might be. Could slightly low engine oil really cause this problem?
Yea, its kinda back again.. Could this simply be the famous 'clunk' people talk of? it's not a real noticeable slip, just barely notice it when you sometimes take off. ??? :confused:
if some of the sheathing is missing on the throttle cable which comes up from the gas pedal I'd replace it and adjust it properly.
I've seen those stick a little which effects how the TPS reads the throttle position. It usually manifests itself as not down shifting to 1st gear when slowing to a stop or corner. There isa a lag before the tranny then downshifts and the truck takes off.
Well it's solved.
Turns out it was a leaky LPG evaporator. They all get old and start to leak internally causing rich running. No wonder it was faster than petrol! Replaced now the truck is slower and slipping gone. Hoping to get better mileage now.
Liquid Propane Gas - his has been converted to run on propane.
