Slipping upon takeoff
To tell ya' the truth man no-one seems to know why they do this.. It 'could' be a case of fuel line? mine runs better on petrol so I attribute it to the s***ty LPG. Although I barely ever run on fuel so I can't tell you 100%
LPG evaporator? what does it stand for? what does it do and where is it located?
sorry for the ignorance us 40 guys dont have this stuff ;)
Mine does the same thing slipping from a dead start.....How do you rule out if it is the VC or tranny? Lock the center diff?
UPDATE** Slipping upon take-off now GONE. Fixed!
After taking the truck to an LPG 'specialist' and have him make things even worse I looked online to find the correct procedure on tuning the gas system. It's smooth as a baby's ass now, really nice to drive.
To others having the same problem I can only really say to check your air filter (replace if old) fuel filter would be a really good place to start and p[ossibly injectors? fecked if I know, just guessing because my fuel system was essentially partially blocked by the adjusters, causing a bad fuel to air mix and just wasn't getting enough fuel fast enough.
Pffft, fixed my ass. The LPG guy actually fxxxed it and I had to spend the time fixing th system, anyway, when the LPG system runs fine the slipping on takeoff does too.. I just hope it doesn't fxxx everything else around it
How do you pull the VC and still have movement? Isn't the VC the thing that links the internals of the transfercase to the rear output shaft?
Did you install a part time kit?
A little while ago I did my viscous coupler in the transfer case, pulled it completely and now I seem to have some sort of slip sometimes when I take off at the lights. I think it could be the slip yokes, maybe? they have been regreased recently so are not bone dry or anything. What do you guys suggest checking?
By 'slip' I mean drive isn't continuous, there is something slipping for a very brief moment just after taking off, unless I gas it hard and then it doesn't happen.
You can remove the VC but require both driveshafts to function correctly. Still 4x4, still have low range. FWIW I can't notice any difference in 4x4 performance, the early 80's never had them in the first place.
I know early 80's did not have. Having just installed a PT kit in my 80 I am having a hard time figuring out how you can remove VC and still have the 80 move. The VC couples to the internals and in turn drives the rear output if I recall correctly. If no VC then nothing to couple to the rear output.
I suppose I should have paid more attention to how it all worked.
No.
You have the same geared differential as early 80's, plus the VC which is essentially a limited slip device when the center diff is not locked.
In your part-time rig it now has zero function whatsoever.
