- Joined
- Apr 19, 2006
- Threads
- 33
- Messages
- 155
Hey guys, I'm trying to wire up my rear 80 series Elocker. I've been reading some really helpful threads on here on how it operates and how to hardwire it using relays instead of the ECM. Which is great because I have NO factory wiring for this axle. The axle was from car-part.com
Here's my problem, the 6 pin connector at the actuator is damaged. The wires "behind" it (wires from diff to connector) are is good shape and can easily make out the colors of the wires. However, the wires coming out of the "front" side of the plug (from connector to harness heading to ecm) are literally all ripped out.
I've looked at the factory wiring diagrams (from yankee toys site) and the colors I have on the backside of the plug don't match up with those on the diagram. I think I need the colors on the harness side of the connector.
The one wire that was intact is Green w/ Yellow. On the diff side of the connector, the color of the wire becomes a bright green. That's what makes me think I need the colors to the other side of the connector.
Can someone peel back the electrical tape and match up the colors for me? I'm trying to get this wired up for my trip saturday.
Here's what I can make out, again on the diff side of the connector.
1 2 x
3 4 5
1 = Dark Green w/ Red (heavy gauge)
2 = Dark Green (heavy gauge)
3 = Bright Green
4 = Yellow
5 = Black
Thanks alot for any help you can provide...
1 2 x
3 4 5
3 = Bright Green
4 = Yellow
5 = Black
