I started to reply to the other post on this and thought my noise was different enough to start a new thread...and that way I don't hijack anyone's thread!
I have two issues going on and I am not sure if they are related. I have OME heavies front and rear with OME shocks/stabilizer and don't have any bumpers or skids to add additional weight (as recommended). I have the blue 3* castor correction bushings from Slee. I had the infamous GRRRR noise that occurred when I let off the gas pedal. I removed the front drive shaft and it got better but did not go away. The forward u-joint was bad (it did not have play when I grabbed it from under the vehicle but was binding when I moved it around after taking it off the vehicle. I can still hear some of the same type of GRRRR after the driveshaft was removed so that causes concern.
I also notice that my rig darts around on the road (may be from the 305/70/16 Swamper SSR's?), so I am going to jack it up and look for play in the bearings and other steering items as well as the pinion nut torque. I did find some play in the PS drag link end, so this may be the cause of the darting.
The bearing preload was recently adjusted by a shop and I am wondering if they got the correct amount.
If anyone has experienced this/these problems, please let me know where I should be looking. I have done some investigating but wanted to post before I started tearing things apart...
