They're always in the right place and the right size, especially if you don't smoke. Found a screaming deal on a 1500 Watt inverter from Costco. Xantrex XPower 1500 for $80. Anyway, it's been sitting around for a month or 2 and today I had some free time. It's not hot yet as I still need some #2 welding cable for power feeds from the battery and a fuse block yadda yadda, but the grounds are all hooked up. I will most likely remove the power switch on the unit and mount it above the recepticles.
