So Ive had a problem for a month or two with my brakes. The old rotors vibrated upon stopping so I assumed they were warped. Well, for Christmas I gave the 80 a complete brake job front and rear with all new rotors and bearings all around. Everything was done correctly ( proper torque settings and bearing preload.) Just to check everything out we measured the old rotors and they were down to just about minimum specs and warped. Now with the new brakes I have a slight pulsing feeling when coming to a complete stop. The calipers looked good and I have no pulling or anything else. The brake fluid is fresh and the lines were bleed correctly. The pads were seated properly and broken in correctly. My only thought is maybe the LSPV valve? It was adjusted after my lift but I was an idiot and did not take before measurements. I did just recently remove my hitch and some weight out of the back so maybe that means I should readjust? What are the symptoms of a LSPV valve out of adjustment? Any other ideas as to what could cause the pulsing?
