•For those replacing or re-sealing a heater core who are not crazy about the vulnerable o-ring seals to the extension pipes, and yet are not thrilled about a rigid solder joint alternative, here is a belt and suspenders redundancy seal that might provide some peace of mind:
1. Parts used:
• Toyota o-rings part number 96711-19016 (thanks SpikeStrip)
•4”L X ¾” ID silicone hose NAPA part number H-167 or equivalent @$2.49 /ft
•6”L X 1” ID radiator hose, scavenged from Autozone formed hose part number C71218 ($7.99).
•4 X 1.5” stainless hose clamps
2. Replace o-rings and pressure test factory seal configuration @ 20 psi. Used a tire valve stem clamped in hose.
3. Cut 4 pieces each ½” in length of the smaller 3/4" tube. Using a new blade remove a strip about 1/8” wide from two for the core side and about ¼” wide for the firewall side. Use a new razor and cut as a guillotine along the tube markings as reference for a straight, square, aligned cut. Final diameters of the sliced segments when squeezed together will be just slightly larger than the pipes so that the two faces are pressed together upon clamping. Clearly a non-split solution would be more ideal but the o-ring flange presents a fitment problem against using the proper diameter hose as bushings. Perhaps multiple layers of heat shrink tubing would work for this step instead of the slotted bushing approach.
4-7. Lightly coat bushing segments with high temp RTV on outer diameter and on both sides of the slit and slide larger hose over the two smaller bushing hoses.
8. Clamp tightly, verifying solidly contacting butt joints at the slits (RTV squeeze-out)
9. Final trim of hoses to clear housing interfaces.
Will it work? Probably couldn't hurt. Anything that might forestall the massive effort to get to this part has got to be a good thing.
Jeff
Jeff
