- Joined
- Dec 11, 2004
- Threads
- 29
- Messages
- 1,435
OK, I searched this awhile back, and never really came up with naything definitive....
When I hit small bumps or when I'm testing the sick articulation on a curb over at Starbucks, There is something in the column that moves.
The steering wheel does not move, but you can feel a clunking in there.
The steering shaft moves ever so slightly when you grab it under the hood. There are two small u-joints on either end, but there isn't a lot if any movement there.
I took the sheild off the lower portion, no grease fittings I can find anywhere....
The PO replaced tie rod ends and stabilizer.....
Where is the movement coming from? the steering box?
Just can't get my mind on this....
Those u-joints look like they would be fun to get to!
