- Joined
- Jan 6, 2009
- Threads
- 16
- Messages
- 103
Does anybody know what thread size the lines are that go into the Steering box on a 83 FJ60? Going to do some braided lines and wanted to see if they had the correct fitting for my box. Thanks
I haven't seen the necessary metric fittings in the Earl's or aeroquip catalog.
PSC sells these adapters to go from JIS to SAE standard, then it's easy to fab custom hoses.
16mm pressure adapter
and
17mm return adapter
HTH
Hope this p/n helps:
From here: https://forum.ih8mud.com/co-wy-hors...j40-while-keeping-air-pump-3.html#post3092615
For the return line you can use the low pressure factory fitting that can be re-used with new tube, eh?
