New interior side panels
Salt Lake Valley
So the old ones were made of crummy carboard stuff, wrapped with cheap vynle, and had ceased holding up the rear speakers. So I built new ones! 1/2" thick plywood, leftover new carpet, a staple gun, an air powered saw, some outdoor wood sealer, a utility knife, and some self-tapping screws. It pretty much muted all the road noise in the cab, and I have rear speakers again! The bed carpet was all manner of nasty too, and I still had some extra new stuff.
SHAG! :grinpimp:
Looks great! The shag is back!
Dye that carpet green and you can call your rig Chia Pet... :)
Chuh Chuh Chuh CHIA
Cool! I need to do something similar to mine. I would like to use 1/4" sheets of plastic or maybe lexan?
6x9's? Factory size? Did you use the ratty cardboard for a template? I'm not a shag fan but I think the hard plastic idea is good.
Thanks guys! It took about 3 hours to build and install. (that doesn't include wood sealer curing time) The Fj60 (Shaggin) Wagon. :D
The speakers are 4x6's. And I did use the rotten cardboard as a template, just lined up two edges on the plywood and traced it around with a pencil. Where the clips were that held it on is what I used as reference for where to pre-drill the holes for the screws. The hard part was cutting out the wood because I couldn't get my hands on a jiggsaw. I would imagine that plastic cuts the same as wood, and it would be invincible to the elements if your wheel wells are rusting out like mine are.
The speakers are 4x6's. And I did use the rotten cardboard as a template, just lined up two edges on the plywood and traced it around with a pencil. Where the clips were that held it on is what I used as reference for where to pre-drill the holes for the screws. The hard part was cutting out the wood because I couldn't get my hands on a jiggsaw. I would imagine that plastic cuts the same as wood, and it would invincible to the elements if your wheel wells are rusting out like mine are.
I have some plastic panels PO put in. They are nice, but i want storage ones from Wagongear.
how did you cut yours out if you couldn't get a jigsaw?
rob
Yaaa baaaaaby, yaaaa...
Neato, but how to you expect to access the rear washer bag now? :eek:
depends of course on the purpose :D , but if my cargo area had deep carpet it would be a doghair-dirt-rocks-woodsplinter-cathair-fishscale-sand-moldy-mess pretty fast.
Cant wait to see how you reupholster the seats and headliner...dont forget the spare handholds and harnesses for safety. Saftey first.
