Well i guess I should finally post up some pictures of my fj80 axle/coil suspension swap. Everything is going strightforward, just slow to to lack of time. Enjoy:
Awesome idea. I loved your truck before. Now you had better get a restraining order! Give some details on the build when you have a moment (i.e.- did you build your own spring/ link mounts, using stock 80 springs with spring mounts welded to achieve desired lift, part time kit on the front axle?, etc.).
Thanks Man.
The 80 FA is a Full Float with a Front E-locker correct?
Man, why don't you see more of these!
FYI, 60 front axles are full floaters as well.
Properly damped, coils will provide a better ride quality...
This is my motivation!
