I'm trading third members with a guy, who has a 73 fj-40 with 4.11's in it. I have an 85 fj-60 with 3.73 in. Is this going to be a straight up fit? thanks guys.
travis
travis
I believe the course splines are only on the birfield/locking hub.
The '73 thirds are not a straight swap, the pinion spline is a coarse thread. For the FJ60 the pinion splines are fine thread, so you can't swap the flanges. Coarse spline pinions were carried up through '77. '78 was the only year with fine spline pinions and 4.11 gears, after that it was fine spline pinions and 3.7 gears (repeat 3.7, 3.7, 3.7).
If you're looking for a straight swap of your 3.7 thirds you need to source a pair of FJ62 diffs. These will have the 4.11 gears and a flange to match your driveshaft flange pattern.
I think the coarse spline axles are pre '69...
Yep, but I thought the 60 had slightly differnet pinion flanges than a 62 (not positive if ti was the tcase flange or the pinion flange).
Didn't I say that??Couple of links to answer the questions:
Cruiser Outfitters
AND
Cruiser Outfitters
Basically, there isn't a pattern we can't come up with regarless of fine or course spline pinions.![]()
