I have been promissing pics to several people for some time. Here is my second alternator installed. The alt shop said that the part number is 7977 se and is a GM replacement alt. It you cant find it that way then tell the part store you are replacing a delco #10463140 or a #1101571. These are 2 discontinued alt's that the 7977 replaces. You might take the smog pump with you to set beside it. The holes match perfectly. You will also need to get a pulley that matches the belt width. The install is easy. The hole in the new alt is a larger diameter so I had to make a sleave for it and I had to put a spacer on to move it slightly forward. Bolts up no problem. The wiring depends on what you want. I put in a second battery and keep it seperate from my other system. I run everything aftermarket off of the new alt and battery and all the factory items on the original system. I had the alt shop make the new alt into a 1 wire system. This way I did not have to install it into the wiring harness. There are connections on the back of the new alt. The I wired to a ground on the frame. The other I ran straight to the new battery. Nothing else. It works great. I will eventually use some type of system to connect to the original battery for emergency situations but for now if the first system dies I can jump form the second battery.
