I have a persistant pinging/knock at WOT or near WOT, especially when climbing a moderate grade incline and I have to back off to half throttle to get the ping to stop, then I'm slower than dirt going up hill. It comes on immediately at 60-65+ when I mat the pedal, but there is a delay at lower speeds... I attribute this to fuel demand exceeding supply more quickly at higher RPMs, thus an INOP secondary (Y/N?)
Motor specs: 81 2F with all smog (all working except the speed sensor due to aftermarket speedo and deleted VSS), smog headers, 2.25" exhaust with cat and flowmaster Hushpower muffler (no leaks), MSD 6A with blaster 2 coil, Denso W14EX-R plugs gapped to .032, 1984 FJ60 distributor (vac advance checks SAT) set to 11 deg BTDC with 20"Hg steady at idle of 660-ish, FJ60 stock carb with 1.47 primary and 2.00 secondary jets. Oh, yeah, I'm running 35's on 4.11 gears with stock 4spd, which will happily roll down the road at 70 mph all day... in Kansas (no appreciable incline).
To diagnose this, I pulled the distributor, checked the operation of weights and springs, as well as the pick-up. I thought maybe I was getting too much advance at the high end, but all seems OK. I reinstalled the distributor and set intitial timing at 11deg BTDC. As I said, the vac advance works (it pulls somewhere around 22 deg of advance when vacuum applied with hand pump at idle).
Moving to the carb, like I said, this is an unmodified stock FJ60 carb that I installed a while ago. I ran through the on-engine tests for secondary operations and it moved freely, I adjusted the throttle linkage to ensure the throttle was reaching 90 deg at full pedal and that the secondary moved freely. I changed out the secondary diaphragm as a matter of course. I also checked the carb float level by running at full throttle then shutting the engine off and pulling over. The level was normal in the sight glass. Following this work, I did the “paperclip test” (thanks to Pin-Head and his videos and posts) and got little to no movement despite a good long pull at WOT up hill at 50+ mph (I thought I felt a momentary mini surge but could have been imagining it, not to mention the paperclip told me otherwise).
So, I pulled the carb and did a mini rebuild, cleaning the vacuum passages with carb cleaner and blowing them out with compressed air, pulling and cleaning the jets and slow jets, replacing the power valve and the top gasket. I checked all vacuum ports and confirmed they were clear. I also checked the throttle position and secondary “touch point”, in so much that the primary throttle moves to near 90 degrees before tipping the secondary a bit (no angle measurements) and that once it tipped, the secondary was clear to open and did open freely.
I reinstalled the carb, retuned the timing to what is stated above, set the paper clip and made several runs… with negative results. At this point I filled up with 93 octane (previously running 87) since I needed fuel. It seemed to suppress the pinging a bit, but it is still there with s no apparent secondary movement.
What am I missing!?!?! I am all out of ideas. PLEASE HELP!
