After much searching on the forum and other sites, several months back I ended up having a Vintage Air system installed in my '78 FJ40 as well as in my sons '76 FJ55. The shop who has done the work is top-notch, the quality of the Vintage Air system is not.
The pig got the first unit. Before it even left the shop, the fan control switch had to be replaced either two or three times. You can't run the temp much beyond the lower 1/3 of the setting without the unit freezing and blowing hot air. Six months post install and still having problems. Nothing but weak explanations from the manufactuer and an unwillingness to accept much responsibility.
The unit in the '40 ran great initially though had the same issue with the fan switch before it left the shop. Now back to the shop and awaiting a micro switch. Manufacuturer still unwilling and apparently uncaring as to the issues or the cause.
As mentioned, I previously found positive feedback on Vintage Air, but with my experience - "Caveat Emptor".
