MUCH cheaper OEM vacuum hose
Gig Harbor WA
I think I 1st saw this mentioned by Dan. But the OEM vac hose(3mm I think) is most often found in a 1 meter length(900mm) for about $10.
But if you order 90999-92003, you get 600mm for retail of $1.83!!!!! I got 6000mm for $14 :D
John
I have no clue. You migh thave some lines that need to use the longer 900mm hose.
another interesting fact. If you look up the part # for each hose, the last 2 digits of the part # is the length you need to cut the hose. so if the part # is XXXXX-XXX30, it would be a 30mm hose.
PabloCruise said:
How much do I need to re-do my '78 federal spec FJ40?
yeah.....I cant spell ;)
and done :)
John
PabloCruise said:
Thanks alot for this Pimp!
BTW, I could not find this post when I wanted to find it again - you may want to change the spelling in the title to "vacuum"...
Nate - There is nothing wrong with the Napa hose except that it's not Toyota. For the purist, everything should remain Toyota. Mr. Land Pimp is a purist's purist.
exactly
Trevor said:
Actually there is a problem with the NAPA stuff - It's not metric and doesn't fit right.
I ordered 10 bags of the 600mm to get 6000mm.
as i mentioned, there are a few lines longer than 600mm I beleive, so you might need the $10 bags :( or splice
beanz2 said:
Pimp,
What is the part number for the 6000mm roll please?
Dave
yeah Al( my parts guy) warned me about that(if I said something) thats why I ordered a bit extra ;)
rather it go to Cruiserheads though :)
Chef said:
Pimp;
Great, now there's gonna be a run on vacuum hose:(
That's great info, thanks!
I am guessing this could be one reason my throttle position solenoid is not getting the vac it needs to pull off?
(grumbling as I pull off NAPA vac hose...)
AND it cooks to brittleness in what...a few years, while the Toyota OEM hose lasts easily 10 or more years.
