How to-install Soft Top Grommets with punch tool
Norfolk United Kingdom
When I bought the hardware for my PAKI top I bought the punch tool so I thought I'd show how it works
First fit the top on and adjust as needed
Line up your holes with a little tension--I just punched through with this awl
next
Line up one of your grommets and make marks with the 4 prongs to line up your punch.
I put the hole a little off center towards the bottom so when the grommet is installed it gives a little more tension---but just a little not too much
Once the marks are made lay the canvas over the end grain part of a 4x4 (use the end grain only so the tool sinks in easily)
punch it
next take the punch tool and line it up with the 4 prong marks and give it a whack with a hamer
install the grommet
Next line up the outer grommet and install the 4 prongs through the punched holes
washer
with the grommet in place flip it over and install the washer, use the end of the punch tool and bend the prongs from the outer grommet over the washer
install the turn fastener with the oval horizontal
Tighten it up
Tighten the nut with a 10mm
check progress and fit as you go
corner
When you do the windshield corner line up the hole but do not add tension to this corner--- it is easy to rip. You could just use a bolt and washer here too.
note the v pen lines I undid the fold seam or it just would not reach the corner
and a couple misc pics
misc pics
and a few more
Remember I said BE CAREFUL in the corner, mine ripped so I sewed in a patch using needle and thread and canvas on both sides and some gasket sealer in the middle. Dont pull on the grommet! IF you have to pull----pull on the material behind it and get it completely lined up okay?
Have to do until I can get a professional repair done:frown:
bummer on the tear but I figure it could use reinforcing anyway so a double or triple layer is in store for the corner when I can get it to the boat shop
Thank you for such an informative post.. Its wonderful to see the top on. Also.. The tear at the front corner was the first reported so far. Even then I will have this issue discussed with my upholstery guy priority one tomorrow. We will see how we can strengthen this part to improve the quality further.
Thank you again for the feedback.
Ehsan
Ehsan
not to hijack this thread but, my top also popped the seam on the left front corner.... not a big deal but enough to make me bang my head against the wall.
repair
I think a little dog ear repair will work with three layers of material maybe all folded under to keep the edges clean
The rh corner v fold pretty much fell apart without unreasonable force probably worth giving these a tug to check em when they are made
I think one thing that made have made it a little tight in the front is how far the front sticks out---the metal bar that mounts along the top is all the way back but now thinking about it I might have trimmed the edge to move that back towards the windshield
a tad and that may have given me a little more slack across the front?
as you can see Eshan is looking at it---so maybe new ones will come reinforced
It tore because i grabbed the grommet and pulled on it so that was my bad---I should of pulled on the material behind the grommet and thought about it a little but it did surprise me when it tore out ---ever see a grown man throwing a temper tantrum in his driveway-----it aint pretty!:lol::lol:
but hopefully the post will help someone else out
and besides the oops the top looks:bounce::bounce2::bounce::grinpimp::cool:
Nice writeup and pics :)
its a good idea to mention that you dont want the top to be really tight when putting the grommets on...I see yours is just right...alil tension is ok...alot is really bad
The canvas tops will tighten up overtime...and if you go to tight now...it will be REALLY tight later.
Yep, thanks for the post! Where'd you get the grommets and tool?
tool and grommets
sorry guys I missed all the questions when I get home I can post up where I got the tool and grommets
IDave you need some grommets? I have extras
If anyone wants to borrow the tool they would need to send me a self addressed stamped mailing container and I'll mail it to them.;)
If you do not return it I will make a voodoo cruiser from my diecast model and curse you with a thousand electrical gremlins and cast thy tub into saltwater;p----just saying
I'm good, thanks!
:eek:
B,
Great thread BTW. This is an object lesson in the power of the search button.:D I just got my OCD beetle top and so I was searching for the how to install info.
Re: the tool that you used I hit the link provided and came up with five pages of tools. Was it this one in particular?
Hole Cutter for Common Sense Eyelet or Twist-Lock
Re: Twist locks and Grommets:
I see this two screw model but not the single screw model that you posted up using. Am I just looking in the wrong place?
Common Sense Cloth-to-Surface Complete With 2 Screw Stud
Again. nice write up. Thanks.
I don't have a Paki top or a ocdbeetle top yet. But the old Kayline tops I do have use a snap in the corner of the windshield. Four tops, three Kayline and one I don't know. All have a snap in that location. Might be a better option than poking a hole for the twist lock.
