Some of you may have seen my post about the gear tower breaking off the transmission case cover. Well, the weather finally warmed up enough so I was able to remove the gas tank and the tranny tunnel today. Unbolted what is left of the tranny case cover. But, I cannot get the gear shift out of the top of the tranny case cover. Following the directions in Haynes it says to push down on the shift lever and turn clockwise. No way will this budge. I have put the piece in a vice and used vice grips to try and push down and turn, but no luck. Anyone have any suggestions on what I'm doing wrong? Here's a pic of the problem part.
Thanks much! This worked! And it was CCW. By the way, my Haynes manual does say "clockwise." The idea of trying both makes sense. I really appreciate all the input from everyone. Beers for the house!
