Told a member here I would post pics. of what I (and others) use as an alternative to the "PullPal".
So here ya go:
Here are some pics. of the axle/anchor I made and use.
This pic. just shows the entire tool and gives you an idea of the scale.
Specs:
1-1/2” diameter hardened axle (discarded from old tractor, but anything similar would work).
Needs to be 36”-42” long to best accommodate all soil conditions (shorter will work where the soil is firm).
Handles of some type…to help facilitate removal of tool when finished (twisting back and forth and pulling up is usually sufficient, or you can winch it out if necessary).
Note: A tab of some sort could be welded to the axle to accept a clevis if you wish (build to suit).
The next image simply shows the bottom of the tool and how it is “sharpened” slightly to make driving the tool into the soil easier. I chose a four sided wedge shape and fairly steep angles. Do yours as you see fit.
Continued next post……………
So here ya go:
Specs:
