Tried to cross a large river here in GA after a friend made it in his 700 twin Polaris. I made a couple mistakes plus the smaller bike, didn't make it.
Long story short, my Rancher and I took a 50 yard float trip down the river. Fourwheeler was completely submerged at times.
Got it home, and after running a couple gallons of oil through it, I've got the oil looking normal. Unhooked the gas line from the carb and drained a quart off in case there was water in the gas. Covering the spark plug hole with my finger and turning the engine over I was able to get a lot of water out of the carbuerator. Installed a new plug, and using a little ether got it to start.
Now it will idle great, and rev some with the choke pulled. With no choke, touching the throttle will make the engine sputter and eventually die.
The engine is now up to temp and has been idling for 20 minutes or so. The exhaust, which was emitting a lot of steam for awhile has quit.
Any help is much appreciated. I am hoping to take the fourwheeler out tomorrow, so if you have any suggestions, speak up!
If this was a Land Cruiser, I'd say it had a vaccum leak, but there is not much opportunity for one on a fourwheeler.
