Is anyone out there working on a swing away tire,gas can,cooler type rear bumper. Would like to haul more gas without the weight on the rear door. Also I dont feel like hauling fuel on the roof rack or inside fj.
Granger said:Easy there Felix![]()
(sissy or something). Felix said:Granger, it just occured to me what you meant. I meant to ask Bob if that was going on his wife'sprincess: ) FJ Cruiser. Not that the truck itself was
I dig the FJC.
I thought maybe Ryan made one for the FJC.
Corey said:I heard the same.
They are also redesigning the front bumper to fit better than the present ones.
The present ones were designed with no FJ at their disposal, and it does not quite fit right.
The newer ones will blend better with the FJs lines.
Corey said:It could be they are all fixed now then.
The first ones that came out as seen on the SEMA rigs did not fit right.
inthewall said:Is anyone out there working on a swing away tire,gas can,cooler type rear bumper. Would like to haul more gas without the weight on the rear door. Also I dont feel like hauling fuel on the roof rack or inside fj.[/quote
All-Pro will be working on one in a couple of weeks. We also just finished upper and lower heavy duty adjustable rear suspension links. I've already bent the lower stock links on my FJ. The stock material they use for the link is .090" thick. I cut mine in half after I replaced it to see how thick it was. I was stuck on a rock with the lower link and the gas tank at the same time and the gas tank won. The factory resin tank and skidplate absorbed the load with no damage while the lower link bent like a pretzel. Our new link kit is made from .281" wall DOM tubing with Johnny Joints on both ends.
