Hey All,
After 10 weeks of waiting, my new Quadrajet has shipped from Sean Murphy Inductions. Pretty excited to see if their work holds up to the hype!
One issue: The new Qjet comes with an electric choke. The current Qjet in my truck has a manual choke "conversion" I'd like to do away with if possible. I understand that you need a fused, switched ignition source (other than the coil) in order to power/heat the choke. Does anyone here have any suggestions on a good wire to tap or connector to use?
For what it's worth - I have a lot of options as all of the smog equipment on the truck is missing. It's a 75 however, with the original manual choke knob, so I don't think there was every any true electric choke equipment present.
I'm running a GM 12SI alternator as well, with a diode in place of the idiot light. I've seen some folks rig the choke to the alternator, but it looks like they typically use an electric oil pressure switch as a relay, which I don't have.
If anyone has some suggestions for a good place to patch this in, I'm all ears! Otherwise, I'll pull out the multi-meter and start testing the empty sockets for a switched, 12V source.
Thanks,
Rick
EDIT: Forgot to mention, the 12SI is internally regulated, but the "warning light" wire is connected to the switch 12V source that used to run to the stock voltage regulator. Would patching the choke in from the same source require way too much draw?
Thanks,
Rick
