LR upper control arm tire chain clearance (1 Viewer)
Price Utah
I am thinking of installing some Light Racing upper control arms on my 2006 Tacoma. Will they give me the needed clearance to install tire chains on the front? I am running 255/85/16 TOYO MT with OME 3" lift.
Are you rubbing the chain on the stock UCA, or inside the fender/body mount? The UCA won't help with the latter.
Between the tire and the UPPER control arm. I can slide my hand between them but that's about it. Does anyone that is running the LR control arm have pics of the clearance?
I don't think that will give you the clearance you want. You'll need to run wheel spacers.
