Your tensioner is in the wrong place. Looks like it could hit the fan pulley. This is how it's supposed to be setup with the 6BT accessories.
Did you use the factory Cummins accessory brackets?That makes more sense. It gets more wrap around the ac compressor. It just comes in contact with the fan pulley unloaded. Was planning on double checking that at some point. It does fit but was worried about the wrap on the ac.
Sent from my iPhone using IH8MUD
mounting it low would seem best for running an intercooler.Beautiful engine. How hard do you think it'll be to service the AC way down there? Makes me glad mine is up high.
you can always get the hy35 with the 9cm hot housing so it spoils quicker. The 4bt I built I used an HE351cw turbo but had 215hp injectors, 191 dv's, bumped timing, 4k gov spring and a #100 fuel plateThe first turbo is an HY35. So a touch bigger compressor than the original h1c. I also lowered my flange an inch. From when that picture was taken. T3 to t25 then the intake and down tube differences also. Might order the adapter and flange and try to pick up the he221 ($250) and it's suppose to be new. I'll look into that belt routing. I have the tensioner for the other set up so it's not a big deal. The are different based on the alignment dowel
