LinkBack (3) Thread Tools Display Modes
Old 06-06-07, 04:03 AM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
LandCruiserSteve's Avatar
TLCA# 6727
Full-length cargo box & sleeper panel
I posted this over on FJCruiserForums a couple of days ago, and thought it might be appropriate here as well.
(Sorry, but lots of pics.)
I began planning this project about a month before I even bought my FJ. And, it was about two months in the designing and actual building stage (a lot of hit & miss) when time permitted.
I wanted a rear storage unit that would meet this criteria:
Cost under $200 total. (I was too cheap to go out and buy something already built. Plus, there were no aftermarket systems that provided exactly what I wanted and needed.)
Be a modular system that could either be used as a rear cargo area storage box only, or a full-length system that could occupy the back seat area as well. (Since I had no use for the back seats, I removed them completely shortly after the FJ’s purchase. However, the cargo area only module could be used for those wishing to retain their back seats.)
Be sturdy enough to carry anything from off-road recovery equipment, to tools and parts, to camping gear, to miscellaneous supplies and gadgetry.
Be completely removable and returned to stock configuration if desired.
Use existing OEM bolt and mounting holes without any cutting, drilling or otherwise molesting the FJ’s original state.
Follow the contours of the FJ’s interior design.
Be professionally-built looking (even though I’m not a professional, nor do I play one on TV).
Supplies required:
Two 4x8 sheets of ¾” plywood.
About 40 feet of ¾” aluminum angle.
2 sets of 24” heavy-duty drawer sliders.
One and a half 6’ x 8’ rolls of gray indoor/outdoor carpeting (from Home Depot @$15.95 a roll).
Carpet adhesive.
Miscellaneous hardware and screws.
I began by building the rear drawer storage box with a center divider and pre-installed the drawer sliders. The box was carpeted prior to installation in the truck. Aluminum angle iron was installed along all edge surfaces and filed smooth. (I used 3" L-brackets to set up the shape of the box until the actual 2" wood screws were installed from the outside.)
I removed the rear tie-down hooks and used their holes as the rear attachment points for the box. (I installed the previously removed tie-down hooks on the forward section of the box to secure it with a pair of turnbuckles to the other set of tie-down hooks.)
Two drawers were built, carpeted, and aluminum angled.
The forward module was created by first cutting to size a base platform that slid snugly up against the rear divider wedge. To level the platform perfectly, I attached pedestal shims along its front base.
The sides of the forward module were installed to meet the height of the rear box, and the front face panel was attached. Upon completion of the structure, I removed the entire forward module to carpet and aluminum angle the edges.
The forward module was re-installed and secured to the side bolt holes that were previously occupied by the back seat attach points. The front of the forward module was secured to existing bolt holes under where the back seats once were. (Eventually, a pair of filler panels were built to fill the spaces between the rear and forward storage boxes.)
The forward module top surface area was measured and a top was created, notched for contour, carpeted and aluminum angled.
The open-able top was attached to the face of the rear storage box with a 45” heavy-duty continuous “piano hinge.” (I’m awaiting the arrival of a flush-mounted lockable latch handle for securing the forward lid when closed, and a pair of hatch struts to hold the lid open when in use.)
(More to follow in next post . . . . )
Steve Bolander
'59 FJ25, '78 FJ40, '07 FJ Cruiser
Bezels? We don't need no stinkin' bezels!
LandCruiserSteve is offline   Reply With Quote
Old 06-06-07, 04:05 AM   #2 (permalink)
TLCA# 6727
But, wait . . . . there’s more!!
Here’s something to sleep on . . . . .
With the front seats all the way forward, there’s an additional 19” of space that could easily be filled by an additional panel. So, I did.
I attached a pair of footman loops to the front section of the forward module, and fabricated a pair of aluminum L-brackets / slot-hooks to the rear of the additional panel. And, attached a pair of ½” threaded female pipe flanges to the front of the panel.
Screwed into the flanges are a pair of painted steel “legs” that provide forward support for the panel. (Rubber cushion tips for the bottom of the legs.)
Now I have a 72” long sleep surface that (snugly) accommodates an inflatable full-size bed air mattress and allows the rear door to close.
Edit: Correction . . . turns out this is a queen-size mattress. A standard full size / double bed wouldn't be as snug.
When the sleep panel is not in service, the legs remove and clip to the bottom of the panel. And, the panel itself stores perfectly into the base of the forward module box.
I’m 6’ 4” and 250 pounds, and the bed fits me quite nicely, with plenty of room to spare.
Well, that’s it. During the course of building, a few scuffs found their way to the interior plastic. However, I came in well under budget. And, the storage boxes and drawers do exactly what I had envisioned.
Time for a rest . . . . .
Steve Bolander
Old 06-06-07, 05:17 AM   #3 (permalink)
Corey's Avatar
Looks good Steve, very nice.
And as the old joke goes, you can definitely sleep in it
Corey
'07 FJ Cruiser
ARB bumper, Warn XD9000, to much to list, see my website
My Forum - My Website - My Rigs Build-up - Roof Top Tent - My Penthouse Video - Maggiolinas In Their Natural Habitat
Corey is offline   Reply With Quote
Old 06-06-07, 08:33 AM   #4 (permalink)
Thank you for a great write up. I appreciate the step by step photos and clear instruction.
have wrench, will travel....
'85 FJ60 ramjet 350, atlas 3.8, NV4500, Dana60s, 39.5" Swampers,hyrdo steer (SOLD)
'90 FJ62 135K, OME, 4.88s, roof tent
'06 Audi S4
'09 Dodge 2500 Diesel
Winslow is offline   Reply With Quote
Old 06-06-07, 08:37 AM   #5 (permalink)
Former Lifer
beaufort-fj60's Avatar
TLCA# 14545
Nice job.
beaufort-fj60 is offline   Reply With Quote
Old 06-06-07, 09:54 AM   #6 (permalink)
adso's Avatar
TLCA# 16713
That's slicker than snot on a doorknob!
"Dad, Napoleon called. He wants his complex back."
2007 FJ Cruiser "Napoleon" ARB bullbar/sliders/rack, Tabor winch, OME heavies front and mediums rear, BFG M/T 33s on ProComps
adso is offline   Reply With Quote
Old 06-06-07, 06:59 PM   #7 (permalink)
TLCA# 6727
I can't ask for a compliment better than that. Thanks, guys.
Steve Bolander
Old 06-07-07, 08:29 AM   #8 (permalink)
Rookie
Great Job Sir!!! Thx for the Info.
GOD BLESS AMERICA
eli1 is offline   Reply With Quote
Old 06-07-07, 08:56 AM   #9 (permalink)
tlcwagons.org
FirstToy's Avatar
nice work! adding to FAQ
I love cachapas!
my wip
The Original blister©
I drink your milkshake!
Old 06-07-07, 03:08 PM   #10 (permalink)
calfj60's Avatar
I like the gun lck onthe front Is it remotly wired like in my work car???
Tim Coffey
87 FJ60 SBC 350 SOA and some other stuff SOLD 5-15-07
94 80 with some stuff New to me 04-28-08
TLCA # 6947
Parts and Carb Rebuilds
http://www.marksoffroad.net
calfj60 is offline   Reply With Quote
Old 06-07-07, 08:13 PM   #11 (permalink)
TrAiLbUs1's Avatar
The box rocks!!! nice job that is some crafty work there
My entire build thread, step into my GARAGE!
http://www.fjccentral.com/vbgarage.php?do=view&id=72
WElcome to FJCCentral.com where all of our members are mentally gone! Come check us out!
http://www.fjccentral.com/index2.php
TrAiLbUs1 is offline   Reply With Quote
Old 06-08-07, 05:55 PM   #12 (permalink)
Degnol's Avatar
TLCA# 14529
That entire setup is the Cat's Ass. Nice workmanship, very neat.
Who is the old homeless guy you posed on the mattress????
Ed
My Anger-Management Class really pisses me off
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers, WhiteKnuckle sliders
Degnol is offline   Reply With Quote
Old 06-09-07, 08:26 PM   #13 (permalink)
mopar's Avatar
That looks good if I didn't have to have a car seat in back I'd build one for my TRD.
mopar is offline   Reply With Quote
Old 06-10-07, 06:52 PM   #14 (permalink)
TLCA# 17389
Outstanding job,great look,not cheap-trifty.
52wheeler is offline   Reply With Quote
Old 06-10-07, 06:57 PM   #15 (permalink)
Degnol's Avatar
TLCA# 14529
Damn, Steve, I hope you don't wake up with morning wood.....you might soil the headliner
Horizontal Momba for sure.......definitely no "Cowgirl Up!"
Still looks very professional!
Ed
Old 06-12-07, 03:04 PM   #16 (permalink)
TLCA# 6727
Yep, there's a disguised remote release switch on the dash.
BTW, you're one of the few that figured out what that was.
Steve Bolander
Old 06-12-07, 03:07 PM   #17 (permalink)
TLCA# 6727
Just some desperate dude with a sign that read: "Will work for opportunity to be near an FJ."
Steve Bolander
Old 06-12-07, 03:25 PM   #18 (permalink)
Rookie
Nice setup!
SCTaco is offline   Reply With Quote
Old 06-21-07, 07:55 PM   #19 (permalink)
calfj60's Avatar
So where did you find the shotgun mount??? I want one for my FJ that I hope to buy in the fall...nothing like planning ahead right??
Tim Coffey
TLCA # 6947
Old 06-21-07, 08:19 PM   #20 (permalink)
FJTex's Avatar
i cant tell you how dismayed i was when i found out that here in NJ its illegal to carry a gun of any sort for any reason other than going to the firing range, hunting, reapir or sale... even then it has to be locked in a box out of reach. i'm from Tx (as you can probably guess) and that was a major shock to me, i was really looking foward to having a similar setup to that in (box and all) in my FJ. i have one question though, i'm considering doing almost exactly the same thing as you, i hadnt thought about modular box for the back seats, i was just gonna permanently sacrifice them so thanks! but my question is, are the drawers deep enough to sacrifice about 2 1/2 - 3"? i'm cosidering having a slide out shelf in addition so that lid contains extra 'counter space' (cleaning fish cooking whatever) so basically i'd have the lid, the sliding shelf and then a 3/4" filler btw. the shelf and the drawer. will that defeat the practicality of the drawers? i hope i'm painting the picture clearly. thanks.
2007 FJC "the short bus" friggin yellow!
AT/4x4
factory locker
A-TRAC mod
TuT Pirate.
the Amish do it with Hoes.
FJTex is offline   Reply With Quote
Old 06-22-07, 01:38 PM   #21 (permalink)
Supporting Vendor
Isotel's Avatar
TLCA# 16898
Wow, Very nice work!
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers -=- CrAwLoRadO.com
Redline Land Cruisers - PM me for info on our products or to order!
Old 06-23-07, 11:53 AM   #22 (permalink)
TLCA# 17556
Very few states these days allow transporting firearms in your vehicle without it being locked up, and pretty much all states require them to remain unloaded in most environments. Even Texas has recently changed its laws recently; some good and some more restrictive.
That's why carry permits are getting more popular. It's the only way most states will allow you to even take them out of our house without having them under lock and key, and even then they usually have to be hidden along with many other restrictions. A few states won't even let you own a gun without a permit.
It makes you wonder what happened to the 2nd amendment, and why so many politicians and other people still think we don’t have enough gun control laws already. That's why I support the NRA.
I had a nice '87 Toyota pickup.
Then a '97 Tacoma with cool stuff on it.
Followed by a '07 FJC TRD SE 6-speed for a while.
Now working on a 2000 Tacoma.
Spaldam.com
spaldam is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/fj-cruiser/159512-full-length-cargo-box-sleeper-panel.html
Posted By For Type Date
fishing rig - Spey Pages This thread Refback 10-24-09 03:09 PM
Storage / Sleeping Platform Build (Updated 4-4-09) - Page 4 - Second Generation Nissan Xterra Forums (2005+) This thread Refback 07-09-09 10:59 PM
Storage / Sleeping Platform Build (Updated 4-4-09) - Page 4 - Second Generation Nissan Xterra Forums This thread Refback 04-08-09 10:24 PM
