So I installed some new, longer lexus/toyota hub studs today .
they were a little longer then what I hoped
could've been slightly shorter... but they'll work.
http://www.wheeladapter.com/wheel_studs.php
my measurement of these lexus IS300/toyota extended studs are:
M12 X 1.50, 52.5 mm actual thread length,
14.20 knurl diameter, 7.5 knurl length
total length 63 to seat - 68 over-all )
( there is a 3 mm shoulder between the threads and knurl )
could be in error +/- .5 mm
mechanical things...
I had to bend (hammer) the backing plate
in a specific location, in order to insert the longer studs.
they just barely clear, but do
backing plate bend location...
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0102.jpg
hammer time...
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0104.jpg
stud removed...
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0105.jpg
new stud being inserted...
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0106.jpg
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0107.jpg
how I pulled the studs thru...
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0108.jpg
studs installed...
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0109.jpg
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0110.jpg
this stuff helps slide that knurl home...
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0111.jpg
wheel reinstalled...
there are .25" spacers installed...
just not the billet ones I purchased.
farked that order up because I didn't pay attention,
and failed to account for the correct center bore diameter.
so I'll need to have muh billet spacer's machined out if I keep 'dem.
btw... these are open end ET 6 spline drive lug nuts
just so it's understood, there's a s*** ton of thread bite
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0112.jpg
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0116.jpg
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0114.jpg
^ I've since painted the stud thread tips black
looks less obtrusive IMO... maybe a pic of that tomorrow (IAGAS) :dunno:
few questions... if ya have the know
my front factory studs were only 30 mm long,
was thinking they were 40 mm. sooo...
1. what is the actual length of the rear studs ? 40 mm ?
2. do the factory Rr. studs have a shank at their base ? how long ?
3. what is the tacoma's front hub diameter ? 97.1 ? More ?
google search brought up too many answers
and they were inconsistent and possibly not reliable.
I could pull one and measure...
but was hoping to know, without doing that.
^ I'm asking specific to the 1st gen, early to mid
as they may be different on the later '01 - '04 tacoma
clarification would be appreciated
here's some other misc. pics...
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0118.jpg
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0120.jpg
pics of the "no bueno" billet spacers
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0127.jpg
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0130.jpg
http://i426.photobucket.com/albums/pp344/TTORADell/tacoma wheel stud extension/IMG_0129.jpg
hammer time...
stud removed...
studs installed...
