Has anyone here done this? There is not much info in the FSM about the way to do it. The tranny side is easy to understand, my problem is with the dash end, I tried to reach under the dash to release the cable and its a no go. I started to take the dash apart as per the FSM and it stated that the steering wheel should come off. I tried to see if I could reach it removing some of the lower dash trim pieces, I had to reassembled due to lack of time. How much of the dash trimmings need to come off to get to the back of the speedo? I've tried the search in the 60's group (same type cable set up as the 91-92) and here and had not found a specific answer to my problem.
Thanks in advance, Cliff
