I've been researching A LOT about ATF.
If you know Rodney, from Wholesale Automatic Transmission Australia, that seems to be the most knowledgeable man on these transmissions in the world, he recommends FULLY synthetic Dexron III or better ATF. He specially recomends Castrol Transmax Z or Allison Transynd.
I put FULLY in capitals as many fluids are advertised as synthetic but are not fully or 100% synthetic, just a blend of mineral and synthetic. Rodney told me that this is important.
I've been going crazy as I couldn't find any oil like this in Spain till I found out that the spanish Transmax Z was the same as the Australian (I had been told that they were different and not Dexron III compatible, so I had discarded it).
If you take a look at this ZF document about ATF's for buses:
http://www01apps.zf.com/kst464/ZF_InteroeleV2_manager/Work/2010-01-01/TE-ML 14_es0701.pdf
You will see that from almost 300 ATF's, Castrol Transmax Z and Transynd are two of the few 9 ATF's that are certified for drain intervals of more than 120.000 Km in ZF transmissions for buses.
Anyway, any fully synthetic fluid from Amsoil, Redline, Mobil 1, Castrol, Allison.... that is Dexron III compatible (note than in some countries Castrol Transmax Z is not certified for Dexron III, but it is 100% compatible, confirmed by Castrol) will be fine.
If you live in very cold climates, put attention in the -40 Brookfield viscosity, that measures the capacity of properly fluid at lower temperatures. The lower the better.
For instance, Transmax Z, Redline and Amsoil are all around 8000. Take this table as a reference:
It's also interesting to choose the one with the highest Flashpoint (it's not that you are going to reach it, but the higher the better they handle high temperatures).
