I stole this idea from Wagongear on the FJ60 forum. Anyway, Firestick makes a neat device that allows a CB antenna to also be your AM/FM antenna.
My stocker antenna was all busted up. I removed it, and stole some pieces from it. The area of the fender where the antenna comes through is curved, so I needed the trim pieces from the stock antenna to match the curve of the body. I then bought a generic CB antenna mount.
The problem is that the stock antenna curved plastic pieces are tall… a few inches; and the generic antenna mount is made to mount to about through ¼” piece of metal. But, the upper half, that the antenna screws into, is just a coupler-nut really. So, I found a piece of allthread that matched the pitch (this took some looking around, as it’s fine thread and most places didn’t carry fine-thread all thread); but then I need another coupler-nut and I really couldn’t find a fine thread one. Back to the electronics store for a second antenna mount (they’re pretty cheap).
I used a shorty CB antenna so I don’t break it in a parking garage. The plastic mouldings from the antenna are not very strong… could not take a lot of abuse. But it works for now.
My last post, I imbedded images… but only half of you guys could see them. Not sure what’s going on there. Picts are in this album (for those who can’t see them): Picasa Web Albums - Brian - projects
Stock antenna disassembled for the plastic moldings
From left to right… bottom piece of CB mount (where the cable attaches), coupler-nut (these first two pieces are all you would normally use to mount the antenna), all thread, two plastic moldings (one below the body, one above), a second coupler-nut (sacrificed from a second CB mount), and finally the CB antenna.
The splitter
Antenna installed
The splitter
Antenna installed
