LinkBack (4) Thread Tools Display Modes
Old 03-19-09, 03:09 AM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
2UZFE swap into FJ80 - building - in progress
Picked up a 91 FJ80 last night with a broken motor. Turns out the crankshaft broke between #1 and #2.
I decided to drop in the 2UZFE VVTi v8 motor with stock auto transmission.
Here is my progress
I project 2 months to completion since my time out in the garage is limited
Day 1: - pull motor
Lets just say, the 3F motor is one of the harder engines to pull. I would hate to put this heavy hunk of iron back in. It would have made things a bit easier if Toyota would have made a two piece fan shroud! Took me about 3 1/2 hours to get the thing out of there, and by my standard, that was way too long. I did spend a bit of timing removing components I won't be needing anymore.
SuperRunner is offline   Reply With Quote
Old 03-19-09, 03:41 AM   #2 (permalink)
vjr021's Avatar
TLCA# 19305
what components will you put back in?
A/C?
1997 Land Cruiser 40th Anniversary #1411
TLCA, FLCA, F4WDA Member
Laughter and tears are both responses to frustration and exhaustion. I myself prefer to laugh, since there is less cleaning up to do afterward.
-Kurt Vonnegut
vjr021 is offline   Reply With Quote
Old 03-19-09, 07:07 AM   #3 (permalink)
Doc
Utarded
Doc's Avatar
TLCA# 17266
Garage
Awesome- keep us updated. What's going on with your doors? Looks like they have something like the LX cladding at the bottom.....
Eric, Utah operations commander- Tall Corn Cruisers.
1993 Landcruiser, 197K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Doc is offline   Reply With Quote
Old 03-19-09, 07:21 AM   #4 (permalink)
Vitesse_6's Avatar
TLCA# 8382
Looks like fun!
I <3 your old 4 Runner
Brian Passey KE7TGH
wasatchcruisers 71 FJ40 Stinky - 94 FZJ80 Ryoku Ryu
Cruiser ring's anyone
Vitesse_6 is offline   Reply With Quote
Old 03-19-09, 08:46 AM   #5 (permalink)
Yes, it will have A/C. There are a lot of EXTRA crap that is used for the 3F motor. The 2UZ is a bit more self contained. Only external sensors are the MAF, and sub-OX sensors.
Not sure what is up with the molding. One piece is gone though, I will need to replace it.
Yeah, 4runner in the background is my bros. SAS conversion right now as well as a 1UZ V8 going in. He hopes to have it done by Moab....ain't going to happen.
Old 03-19-09, 09:46 AM   #6 (permalink)
phxtlc's Avatar
Very interesting...Can you post up a parts list as you go along? Also details on your engine mount fab would be great.
Copper State Cruisers #091
1992 FJ80 230k+ miles. OME 2.5" medium with 295/75/R16 Nitto TG's
“Neither current events nor history show that the majority rule, or ever did rule.”
phxtlc is offline   Reply With Quote
Old 03-19-09, 12:01 PM   #7 (permalink)
Currently Cruiser-less...
ChuckB's Avatar
Location: Honolulu, HI (Soon to be San Diego via VA and RI)
TLCA# member
This exactly what I would like to do eventually. Where did you get the tranny, what is it out of? What kind of adapter issues are there? Sweet build!!
Subscribing.
PRESENT:
'01 Saab 9-5 SE Wagon 102k mi. (wife)
'93 Volvo 940 312k mi. (my DD)
still looking for another Cruiser...
PAST:
'72
'00 LX-UZJ100
'86 FJ60
ChuckB is offline   Reply With Quote
Old 03-19-09, 12:12 PM   #8 (permalink)
Have you checked carter clearance space?
A friend is having a bit of trouble fitting same engine into a FJ62, had to cut the firewall to put the engine behind the front axle. Relocated engine mounts, gearbox/tranny moved back also. Custom lenght driveshaft, etc.
Watch for full PS compresion clearance and double check if there's any space left for the alloy carter.
Jose.
'96 FZJ80... almost stock
josepo is offline   Reply With Quote
Old 03-19-09, 12:26 PM   #9 (permalink)
fj40peru's Avatar
Hi, we are doing the same swap, but to a FJ62... the problem we found is that the 2uz always comes in Trucks that doesent have front solid axles (Ejes, in spanish)
we are cuting the fire wall and puting the engine half out half inside the cabin...
http://forum.ih8mud.com/60-series-wa...-n-videos.html
I hope thet thread can help you
===FJ25 56===
===FJ40 84===
===FJ62 85===
===FZJ80 94===
===FJ60 81=== SOLD
===FJ40 80=== SOLD
www.LandCruiserPERU.com
fj40peru is offline   Reply With Quote
Old 03-19-09, 12:33 PM   #10 (permalink)
LandCruiserPhil's Avatar
What part of the country is this taken place?
"Knowledge without experience is just information"--Mark Twain
Copper State Cruisers #003
LandCruiserPhil is offline   Reply With Quote
Old 03-19-09, 12:39 PM   #11 (permalink)
I am not sure how the oil pickups are, but you might be able to fit a LS400 or SC400 oil pan on.
The mating surface of the engine/bellhousing will be forward about 4" so no need for modifying firewall. The R150F is about 4-5" longer from bellhousing to shifter so the engine came come foward that amount.
R150F is out of 3.0V6 4runners/trucks. I make custom bellhousings and flywheels for the manual conversion behind the toyota/lexus V8.s
I am located in Orem, Utah.
Old 03-19-09, 12:41 PM   #12 (permalink)
Supporting Vendor
sleeoffroad's Avatar
The 2UZFE does fit in a 60 body without any cutting. You have to use a Land Cruiser oil pan and not a Tundra oil pan. Then it clears the diff.
Christo Slee
www.sleeoffroad.com
sleeoffroad is offline   Reply With Quote
Old 03-19-09, 01:12 PM   #13 (permalink)
Not sure if this is hijacking the thread... but guess all this info helps SuperRunner.
Christo, do you have more detailed pics?
This Tundra engine has a front oil collector then the oil pan is lower in the front, do LC's have a rear one?
Jose.
Old 03-19-09, 01:13 PM   #14 (permalink)
Supporting Vendor
Yes, you change the 2nd and 1st oil pans as well as the oil pickup. Also change the Tundra filter housing to a Land Cruiser one.
Christo Slee
www.sleeoffroad.com
Old 03-19-09, 01:17 PM   #15 (permalink)
fj40peru's Avatar
WOW!!! cool photo, we are puting the engine from the back of the front axle, also to have a better performance at the race...
you have more photos of that truck, but from the buttom part?
===FJ25 56===
===FJ40 84===
===FJ62 85===
===FZJ80 94===
===FJ60 81=== SOLD
===FJ40 80=== SOLD
Old 03-19-09, 02:05 PM   #16 (permalink)
livin a poor college life
Lka1988's Avatar
Garage
What part? Are you in a shop?
I'm definitely keeping an eye on this one....being local is a huge plus.
Lane Anderson
'91 TRD FJ80 "Katie" - 265k, 3FE, 3H4, 860+1/850J+1, locked, 33's, Taco rims, custom front bumper, custom roof rack, LineX'd, Dual batts, CB, HIRs, OBA, GPS, aux lights, aux fan, desmogged, pintle hitch, ROTF
'63 VW Type 1 - 43k, 1600cc, Anthracite, 100% restored, Blog
"VWs and Cruisers... How can you go wrong?!?" -CreeperSleeper
Lka1988 is offline   Reply With Quote
Old 03-19-09, 02:14 PM   #17 (permalink)
Near the Orem city park. I got a shop out back.
Old 03-19-09, 03:16 PM   #18 (permalink)
lt1fire's Avatar
What transfer case are you using??
Al
92 fj80: full 6 in slee lift, electric fans, 37" Goodyears, custom sliders, custom front bumper, slee ss extended brake lines, Bud built tie rod/relay rod, XRC 10 winch
Olde North State Cruisers
lt1fire is offline   Reply With Quote
Old 03-19-09, 03:34 PM   #19 (permalink)
that is where it gets tricky. Due to the offset rear, there could be a problem with that.
That is one part of the swap I have yet to figure out.
Old 03-19-09, 03:35 PM   #20 (permalink)
Lka1988's Avatar
Garage
Does the stock TC not bolt up to the R150F? I thought there were adapters for that...
Lane Anderson
Old 03-19-09, 04:57 PM   #21 (permalink)
No it doesn't bolt up. But I guess there could be adapters to do so. I have never looked into that. I also have an R151F that uses the 4cyl gear driven t-case. THere could be an adpater for that as well....or at least an older t-case from the 4 speed manual.
Old 03-19-09, 06:44 PM   #22 (permalink)
TLCA# Stolen
Looks like a cool project!
One question, not sure about the 60, but every motor pull I have seen (other than the two I have done), the outer edges of the front end are removed. That's more work than necessary, so I wonder what the advantage is?
I'm jealous, have fun.
2- 91 FJ80's, one smashed
In the family
74 FJ40 w/PTO winch, tow bar
83 FJ60
84 FJ60
90 FJ62 w/damage inducer
94 FZJ80 w/damage multiplier
95 FZJ80 " "
03 UZJ100
TX Cruiser is online now   Reply With Quote
Old 03-19-09, 08:53 PM   #23 (permalink)
I am not seeing any adapters to bolt up LC transfer case to a different tranny. Anoyone got any ideas?
Old 03-21-09, 06:09 PM   #24 (permalink)
So I decided to stick with the stock auto. Trying to deal with a non-offset tranfercase is something I didn't want to do on this project.
I have made a temporary adapter until I get an adapter flange made. I will also use the UZ flex plate and the stock flexplate. I will use an aluminum spacer in between the two flex plates. I will take my plans to the machine shop early next week, and hopefully they will get it done soon. They are known for taking awhile, but they do good work at one of the cheapest prices around.
The motor/trans combo will sit forward an extra 4 inches still, not a big deal. $200 in driveshaft mods will fix that. Shifter for the t-case will just be bent back a little bit. I might even weld on plate further back on the transmission to keep it in stock location inside the vehicle.
I will use Lexus engine mounts. I am pretty sure they will work better than the Toyota mounts...as long as the bolt holes are the same on the iron 2uz block.
So far I am ahead of schedule on this project. Who knows, at this rate, it could be drivable within the next 30 days.
Old 03-21-09, 06:35 PM   #25 (permalink)
NLXTACY's Avatar
TLCA# 19015
damn that is going to be freaking cool!
ふざけんなよ!
Old 03-21-09, 08:44 PM   #26 (permalink)
jvazquez53's Avatar
I imagine the power increase on that engine will be noticeable...
Keep us posted!
José
White 92 FJ80 "El Tractor Dos"
Gray 9
2 FJ80 aka "La Tractorcita" (Daughter's FJ 80)
83 FJ60 "El Tractor "(RIP) 2009
76 FJ40 - sold
74 TY250 - sold
83 IT 175 - sold
85 TY350
DT250 - sold
91 Isuzu P/UP - sold
79 Plymouth Trailduster - sold
72 Jeep Commando - RIP
jvazquez53 is offline   Reply With Quote
Old 03-21-09, 09:01 PM   #27 (permalink)
still solving problems...
NorCalDoug's Avatar
TLCA# yes, I have one
way
a couple pairs of pink panties...
Another convert to the Church of Latter Day Swank, a sub-cult of Shahrislam
"...Opportunity doesn't knock, you have to kick the fuckin door in and drag the bitch out screamin." -- Ullr
"I have more respect for people who change their views after acquiring new information than for those who cling to views they held thirty years ago. The world changes. Ideologues and zealots don't." - Michael Crichton
NorCalDoug is offline   Reply With Quote
Old 03-22-09, 06:36 PM   #28 (permalink)
alia176's Avatar
so, the V8 mates to the auto tranny bell housing w/o any issues? I assume the reason for doing the two flex plate thing is so that the torque converter bolts up easily?
thanks.
'96 his
'97 hers
alia176 is offline   Reply With Quote
Old 03-22-09, 07:18 PM   #29 (permalink)
Lka1988's Avatar
Garage
NICE!! A V8 totally belongs in there.
Lane Anderson
Old 03-22-09, 07:57 PM   #30 (permalink)
Yup, pretty easy. THere could possibly be some wiring in the way. on the 1UZ the EGR piping would be in the way of the adapter, which of course could be re-routed. I don't have the 2UZ yet, so I will have tow wait and see.
Two flex plates because yes you still need to bolt the torque converter to something and it already has all the right holes.
I am sure something like this would sell for around $350-$400 for a manufactured kit...possibly less.
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/273882-2uzfe-swap-into-fj80-building-progress.html
Posted By For Type Date
Outer Limits 4x4 Board :: View topic - 2uzfe into 80 has it been done This thread Refback 08-19-09 05:06 PM
Anyway to disable traction control in drive-by-wire - Tundra Solutions Forum This thread Pingback 08-14-09 04:25 PM
80 Series V8 conversion. - Page 3 - Expedition Portal Forum This thread Refback 03-19-09 01:21 PM
80 Series V8 conversion. - Page 2 - Expedition Portal Forum This thread Refback 03-19-09 12:14 PM
