Old 02-04-07, 01:58 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Garage
Parking brake?
Had a '97 LX450 at the shop, very clean truck, 83K on the clock...
Parking brake was not working properly...
Anyone that lives in the rust belt knows that the paking brake on a Toyota needs to be used frequently to stay functional...or it will rust up.
The only thread that I found out here about the parking brake was about the wasted/rusted to hell steel cam lever and aluminum pivot block being frozen solid, and how to free them up.
Many times, replacement is the only option, as was with this truck.
In the following pictures, I hope to share my idea of what has worked at keeping the parking brake functional for years of service.
In order to remove the rotor to get to the parking brake assembly, the caliper and pad mounting bracket must be removed. These can be set aside, or, I just tucked them up by the coil spring.
Old 02-04-07, 02:04 AM   #2 (permalink)
Poser's Avatar
TLCA# 1856
Garage
Next, the rotor needs to be seperated from the wheel bearing hub. This can be done by using the two 8mmx1.25x30 bolts threaded into the holes in the rotor assembly and forcing the rotor off the hub. Sometimes the rotor can be a pain, but most times it will pop free with little effort, and then can be set aside.
Old 02-04-07, 02:18 AM   #3 (permalink)
Poser's Avatar
TLCA# 1856
Garage
So with the rotor removed, you can see the parking brake shoes... these shoes still had life in them, so the project was replacing the levers and mounting blocks, as they were rusted up solid and would not move.
Here are pictures of the rusty cam arm and non-reuseable link that needed to be cut off with a small rotory tool in order to get the bad brake pieces off the backing plate..
Old 02-04-07, 02:20 AM   #4 (permalink)
Poser's Avatar
TLCA# 1856
Garage
I cut the cam arm with the rotory cuttoff tool as far as I could, and then snapped it off the rest of the way with the Vise-Grips..
Old 02-04-07, 02:27 AM   #5 (permalink)
Packrat Extraordinaire
nanuk's Avatar
TLCA# 3905
Thank You, this is the motivation I needed to finally get mine done before I get to that stage. Have never had the rears apart (even having had 2 80's), so the pics and how-to helps.
Mine is not frozen up yet, but after my front knuckle service, I need to do my rear bearings, brakes etc.
74 fj40: LONG term project, 35" BFG's, 2.5 rancho lift, 2" body lift, 465, 350, SR, 8274-50
75 fj40: SO, TBI 350, 465, ARB's, 8274, saginaw PS, 4 wheel discs, 35" Boggers
78 fj40: 350, turbo 350, NP205, truck rear, more rust than mouse crap- barely!
93 fzj80: lift, BFG 35's, ARB's X 3, M12000, homemade rear bumber, Metal-Tech sliders, CDL, and tunes
96 fzj80: 285 AT's, CDL, factory lockers, Hers
nanuk is offline   Reply With Quote
Old 02-04-07, 02:31 AM   #6 (permalink)
Poser's Avatar
TLCA# 1856
Garage
So with the old junk out of the way, we can focus on installing the new pieces....
The cam pivot block is made from aluminum and the cam pivot pin and cam arm are made from steel. We all know how well those two play together in the rust belt... The sealing boot needs to be installed on the arm, and then the arm, pivot pin and pivot block get coated in anti-size...
Old 02-04-07, 02:36 AM   #7 (permalink)
Poser's Avatar
TLCA# 1856
Garage
A healthy coating of anti-sieze has proved to work well at keeping these pieces functioning properly over the years....
Old 02-04-07, 02:41 AM   #8 (permalink)
Poser's Avatar
TLCA# 1856
Garage
Installing the new pieces to the backing plate...
Old 02-04-07, 02:46 AM   #9 (permalink)
Poser's Avatar
TLCA# 1856
Garage
Make sure that when installing your new cam lever boot, that it gets seated in the groove that is formed by the backing plate and pivot block...
Old 02-04-07, 02:47 AM   #10 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
FAQ material
seeing that makes me want to preemptively lube mine. it will eventually happen to us just 30 years down the line.
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is offline   Reply With Quote
Old 02-04-07, 02:52 AM   #11 (permalink)
Poser's Avatar
TLCA# 1856
Garage
Next,
You noticed that I had to cut the cam arm to get the assembly out of the backing plate...well the cable link to the shoes was not going to come apart...and needed to be replaced.
If you live in the rust belt, be sure to order this cable, pin and retainer for both sides, as they will likely not be reuseable...
Old 02-04-07, 02:55 AM   #12 (permalink)
Poser's Avatar
TLCA# 1856
Garage
Installing the new cable, pin and retainer.....and installing it onto the parking brake shoe lever...
Old 02-04-07, 03:04 AM   #13 (permalink)
Poser's Avatar
TLCA# 1856
Garage
After attaching the cable link to the parking brake shoe arm, it is just a matter of putting the shoe retainers and springs back together....installing your new parking brake cam arm return springs and attaching your cable to the arm.
You then can put the brake pad retaining bracket back on and the caliper.
As stated earlier, I am a fan of anti-sieze, so that gets used here on the bracket bolts and the caliper bolts...
Old 02-04-07, 03:05 AM   #14 (permalink)
Poser's Avatar
TLCA# 1856
Garage
After installing the rotor, I coated the brake pad bracket retaining bolt and caliper pin assemblies with anti-sieze...
Old 02-04-07, 03:14 AM   #15 (permalink)
Poser's Avatar
TLCA# 1856
Garage
After everything is back together, you now can adjust the parking brake shoes. The adjuster is on the lower section of the parking brake assembly. This also gets a little anti-sieze on it when things are apart.
There is a little rubber plug in the rotor that needs to be removed in order to get to the adjuster. You will need some form of long, flat screwdriver to get into the adjuster. I install two lug nuts, 180 degrees off from one another, to keep the rotor secured properly to the hub when adjusting the parking brake shoes. I adjust then so that there is a bit more than a light drag on them, and call it good.
Remember to put the little rubber plug back in when you are done.
Old 02-04-07, 03:18 AM   #16 (permalink)
Poser's Avatar
TLCA# 1856
Garage
Going to do oil sampling while it was here...
Front diff oil does not appear to be as 'fresh' as the transfer case and rear diff Ryan...I would have a talk with your lube boys next time you see them...
Old 02-04-07, 05:54 AM   #17 (permalink)
drsales's Avatar
How true! Both of my trucks have had the parking brake treatment. Very common here in Ohio. Nice job with the write up and pics. Grade A for you
95 FZJ 80, Locked, 226k+, Original Stocked & HG, George's Map and Dome, PHH, Mobile 1, Slee Wire Harness, J.Deere Lights, 100 Series Pads, upgraded Stereo w/ XM and lots of Dynamat. Lost to the boys.
2000 100 series with 160k. Mobile 1 oil, diffs, trans and transfer. JD low beams. Upgraded stereo & speakers, Dynamat doors.
drsales is offline   Reply With Quote
Old 02-04-07, 11:45 AM   #18 (permalink)
flem0061's Avatar
Thanks Steve! Great write up.
It's not too likely that the front diff got that dirty in the last 2000 miles is it? Hmmm, I wonder what that shop did with the other couple quarts of Amsoil that I gave them if they didn't go in the front diff....
1985 FJ60 Stock *SOLD*
1997 LX450 Locked and Stock
1973 VW Super Beetle
1987 Honda CMX250
2005 Subaru Impreza RS (DD)
2005 Subaru Forester (Wife's DD)
flem0061 is offline   Reply With Quote
Old 02-04-07, 12:37 PM   #19 (permalink)
Hey, if you dont mind me asking, how much was it for all of the parts to do both sides?
Don
I put 80 axles under my Land Rover, killed the rest of it, then bought an 80.
Discyota is offline   Reply With Quote
Old 02-04-07, 02:56 PM   #20 (permalink)
Poser's Avatar
TLCA# 1856
Garage
Don
PM cruiserdan... <--- this is a link
Be sure to tell him that you want the cable link between the cam arm and parking brake shoe arm, along with the pin and retainer for it, both sides.
Old 02-04-07, 03:06 PM   #21 (permalink)
TLCA# 13006
What did all the parts cost you?
My parking brake mechanism is not working as it should either, Damn New England Salt. I think a freshening up with new parts and anti-seize would fix the problem.
Did you have any issues with the parking brake cable?
1996 FZJ80. Mostly stock. 285 Cooper STTs, Projector Headlights, Diff. Lock Mod., New 40th two-tone leather.
1997 FZJ80 40th
6" Slee Lift, Sliders, 2" Body Lift, 11.00x16 XL's, 4.88, rear Aussie Locker, ARB Snorkel, ARB Bull Bar, 10,500 MM Hydraulic Winch, LightForce XGT's, Laptop/GPS/, Intercooled Turbo, Diff Switch, 3" SS exhaust.
MSGGrunt is online now   Reply With Quote
Old 02-04-07, 03:10 PM   #22 (permalink)
TLCA# 13006
Maybe Dan can chime in and let us know what a "kit" that included all of the above would cost us instead of all of us PMing him.... How about it Dan???
I'm sure this is a very common issue for us that live in the regions of the country that use salt on the roads in the winter.
1997 FZJ80 40th
Old 02-04-07, 04:15 PM   #23 (permalink)
Trunk Monkey's Avatar
TLCA# 11251
I've got all the parts sitting on the bench waiting for a warmer day. Thanks for the write up, I'll be putting it to use!
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Join or renew your TLCA membership - CLICK HERE
Trunk Monkey is online now   Reply With Quote
Old 02-04-07, 04:42 PM   #24 (permalink)
flem0061's Avatar
Brake parts
Parts for both sides cost $97.50 shipped to MN.
1987 Honda CMX250
Old 02-05-07, 08:20 PM   #25 (permalink)
Do you have all the part #'s?
95 FZJ80 , non-locker, 285/75/16 Kumho M/T 834's, CDL, FS $3500!!!!
"The Green Booger"
Indy Travis is offline   Reply With Quote
Old 02-05-07, 11:08 PM   #26 (permalink)
robchad's Avatar
Great write up with good picks, must have a look at mine not working too good these days.
If at first you dont succeed, then skydiving's not for you..
91 HZJ80 4.2 diesel
duel batteries, tinted windows, uhf & 27mhz, bushman fridge and other stuff.
www.offroad80s.com
robchad is offline   Reply With Quote
Old 02-05-07, 11:41 PM   #27 (permalink)
Poser's Avatar
TLCA# 1856
Garage
All pieces, like many things with Toyota, are individual. There is not a 'kit' for this project.
I will put together 'my' recommended parts list shortly.....
Also-
The parking brake shoes were not replaced when doing this, so they are not included in the price that Ryan posted up out here.....
Old 02-06-07, 07:09 AM   #28 (permalink)
Mexican't
agomez's Avatar
nice write up thanks for the info and pics.....
2000 uzj100
1995 Fzj80 Pearl Gray mallcruiser with damage multipliers front and back
scale: 1/4"=1'-0"..........
agomez is offline   Reply With Quote
Old 02-06-07, 07:49 AM   #29 (permalink)
stayalert's Avatar
Is your antisieze compatible with rubber? Just wondering...I've always used high temp synthetic brake grease on the caliper pins...I too am a fan of antiseize....Living in New Engalnd I did the same rehab on my '94 about a year or so ago... My parts were much like yours in condiiton. Nice job!
stayalert is offline   Reply With Quote
Old 02-06-07, 08:10 AM   #30 (permalink)
Driley's Avatar
FAQ if not done already!
Great write up!!! I was just about to start another newbie thread about adjusting the parking brake. Now I know what it looks like in there.
Excellent Job!!!
Riley
1994 FZJ80 Stock White Locked DD / ARB (Winch) Front Bumper
1991 BMW 735i - 3rd owner - Full History - White (Of Course...) - Fixing all of the electrical gremlins... SOLD!!! Ask me about it...
2008 Highlander Sport / Cypress Pearl / 56 Miles And Counting...
Driley is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/135349-parking-brake.html
Posted By For Type Date
Ebrake This thread Refback 12-23-08 04:27 PM
