Old 09-09-09, 03:01 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
DavidW's Avatar
A 22RE injector problem I had
I was having trouble with my 87 4Runner. It is the 22re with the std transmission. Prior to a trip to Colorado, I replaced the timing chain, gears and guides with an Eng. Builder kit, and replaced the wires with OEM wires. After running well around home (Texas) for around a week, we hauled the Runner to Colorado where after a day of driving it developed a miss. I pulled the wires and found that it was on #1. The plug was getting spark. I moved the plug to see if the miss followed the plug. It did not. I checked compression and have 150 lbs on #1. We limped it back to camp and changed all the plugs, the rotor and the cap. When we changed plugs, we noticed that the plugs were all very white like they were running lean. To me it seemed that the problem was injector related because of haveing spark and compression but no power on #1. The Runner would sometimes run fine while in Colorado and sometimes miss from then on. It would seem to "catch" when I would run it up to over 3500 rpms in 1st and then run sometimes run good for a time.
When we got home I sent some injectors that I had from another 22re to Witchhunter and had them cleaned and rebuilt. I installed them and still no bueno. I spoke with a Toyota mechanic here locally and he said that if it were a problem with the wiring for the injectors then it would effect 2 cylinders instead of 1.
Well, thanks to Roger Brown, I think that I might have fond the problem. Something that didn't show up in any of the searches that I did all over the place.
I got the injectors back from WitchHunter (thanks!!!!) and insalled them, fired her up and dammit to hell it was still missing. Run it down the road and no bueno at all.
Emailed Roger and he promptly got back with me. Short and sweet:
Might check the injector wire splices:
http://www.4crawler.com/Photos/Misc/...ctorSplice.jpg
http://www.4crawler.com/Photos/Misc/...Wiring22RE.jpg
4x4Wire's TrailTalk Forums: Fuel injection problems
4x4Wire's TrailTalk Forums: *UPDATE - FINALLY DONE!* Some Q's re: injector splices....
Pulled my plenum off and started cutting into the harness and the further I went I started finding moisture. The harness is (or was) completely unmolested except for the a/c wire coming out of it. When I found the injector hot wires, this is what I found:
Corroded but not seperated.
Next I started looking for the ground wires and found them a few inches further up the harness. Holy shit!!!!
Time to get the soldering iron out!!!
After soldering the wires and rewrapping the harness all is well. The truck is back to running excellent.
Thought that I would plst this up in case anyone els has a similar problem.
"Can you just imagine how funny it would be to see Nolen, painted blue/green wearing white cut off overalls, being chased by a home built unicorn? The real kicker would be Mark as the man behind the curtain." ~... David Dearborne
http://www.marksoffroad.net
Chief of the Fire and Rescue of the White Trash of Elwood! By Gawd!
In our system, the police do not exist to defend our rights, but rather to enforce the will of the nearest state functionary who claims the 'authority' to violate our rights
DavidW is offline   Reply With Quote
Old 09-09-09, 04:03 PM   #2 (permalink)
corax's Avatar
Garage
Junky Toyotas . . . the harnesses are so poorly sealed that a bare wire only takes 22 years to corrode
Good info though - did you use any "liquid electrical tape" or RTV to help seal those up before you wrapped them?
-Keith- kb3scj
'88 4runner SR5 - 3L 7MGE swap - Marlin HD W56 - 4.56 V6 Thirds, LSD up front - 33x10.5 BFG KM2's- home fab front and rear bumpers - NWMP 14 gal aux fuel tank
"Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
corax is offline   Reply With Quote
Old 09-09-09, 04:52 PM   #3 (permalink)
DavidW's Avatar
Nope just soldered them, heat shrink and high quality electrical tape.
Old 09-10-09, 07:20 AM   #4 (permalink)
Jukelemon's Avatar
Yeah, the wire splices are a common issue. However, I never hear about them in older 22re's-seem to be an early harness issue.
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 09-10-09, 09:50 AM   #5 (permalink)
arndog123's Avatar
I had the same exact problem when I converted my '86 truck over to EFI. Now that I think about it, the donor rig was an '87 4Runner.
1997 CE Land Cruiser: Locked, ARB w/ M12000
1996 LX450: Locked, ARB w/ no winch yet
1990 XtraCab 4x4 pickup: ARB w/ M8000
1986 Standard cab 4x4 pickup: Locked, ARB w/ XD9000
1985 XtraCab 4x4 pickup: ARB w/ M8000
1995 Acura Integra (Daily Driver)
arndog123 is online now   Reply With Quote
Old 09-10-09, 09:37 PM   #6 (permalink)
I wonder if this can cause a loss of power with out the miss?
missouriman is offline   Reply With Quote
Old 09-15-09, 12:39 PM   #7 (permalink)
COMITX's Avatar
Dave,
Was your computer throwing any codes prior to the fix?
Thanks,
Ken
FJ60 "Moose", FJ62 "Mule, UZJ100, '86 4Runner "Junior"
COMITX is offline   Reply With Quote
Old 09-15-09, 08:33 PM   #8 (permalink)
DavidW's Avatar
No codes at all.
Old 09-16-09, 01:20 PM   #9 (permalink)
toy4xfun's Avatar
thanks dave now i have to pull back my harness and check. well i guess i will have to buy that harness wrap from painless. damn the wife is going to be mad.
QUIT SUCKING MY OXYGEN
toy4xfun is online now   Reply With Quote
Old 09-16-09, 02:21 PM   #10 (permalink)
DavidW's Avatar
I think that you can get by with using some cheaper hard plastic wrap and seal the wires up good before you put the plastic wrap and then tape it up like they do from the factory.
Old 09-17-09, 06:27 AM   #11 (permalink)
toy4xfun's Avatar
yea i know but i have been looking at doing that for a while now and i like the look of the painless wrap.
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/311436-22re-injector-problem-i-had.html
Posted By For Type Date
damn gremlins This thread Refback 11-11-09 06:53 AM
UltimateYota.com - 22re Misfiring This thread Refback 09-15-09 09:03 PM
