well i always use this site for looking things up, but i have never done a repair thread so here is a little job i needed to get done today.
tools for the job
-30mm socket
-breaker bar
-two 14 mm wrenches
-2x4
-hammer
-flat head screw driver
-gear oil
-new seal (national seal pn-1177)
first things first, put on the parking brake, or block the wheels, or both if your not in the flatlands like me, and take out he four bolts holding the driveshaft to the pinion flange
use either the flat head or my favorite tool (your boot) to knock the driveshaft loose from the flange and swing it out of the way
use the 30mm socket and your breaker bar to get the lock nut off , so that the flange may be removed
now heres one of the tricky parts, get the old seal out. my method involved tapping the sharp end of a screwdriver through the middle of the seal and prying it out, completely destroying it in the process. make SURE you get all of it out, like the little spring circle on the back side of the seal.
clean off your surfaces and tap the new seal into place with a mallet and block of wood so as to not damage the new seal.
its probably best that your clean up your old flange, get all the gunk off so the seal sit properly
i went ahead and painted my flange just because. get it back on, replace the washer and tighten down your lock nut. i found a lot of different specs on what it was supposed to be cranked down to, but mainly it was just tight as ****. i had my wrench set at 150 ft pounds and didnt quite reach it because its a short wrench. make sure to notch the nut with a screwdriver or punch so it doesnt back off.
bolt back up your driveshaft and your rollin'!
tools for the job
-30mm socket
-breaker bar
-two 14 mm wrenches
-2x4
-hammer
-gear oil
