Old 05-21-07, 01:00 PM   #1
what he said
Mace's Avatar
FJ60 hydro assist porting..
Figured I would outline this here..
Tapping a FJ60 box for full hydro is not a complicated task.
Tools needed,
14mm Socket and ratchet,
Pittman arm puller (and a big socket or crescent wrench)
Drill (Drill press makes for straighter holes)
7/16" Drill bit
1/4" NPT pipe tap.
A bit of grease.
Something to wash ALL of the metal pieces out.
It is up to you if you want to replace the seals or not. Spector does sell them individualy. Or you can get the kit for something around $120 or so..
First thing, remove the pittman nut and the pittman arm.
The nut typically is easy to remove, the arm tends to cause more difficulty..
I got lucky with a 2 arm puller. Most have had better luck with the Snap on pittman arm puller.
Basically you put a TON of pressure on the bolt on the puller, then smack the end of the bolt with a hammer. This breaks the tension of the pittman arm and makes it come off a lot easier. Penetrating oil helps quite a bit as well.
Once the pittman arm is off you can remove the top cover that resides above the sector shaft. Be aware that it will not just "pop" off. It has a O ring that may make it tough. The Sector Shaft is also threaded into the top plate (center adjusting nut) so you need to remove the lock nut and thread the "bolt" back out of the top plate.
I am kinda gay.......
My Myspace
Old 05-21-07, 01:04 PM   #2
what he said
Mace's Avatar
After taking the top plate off you can slide the sector shaft out by pushing from the pittman end up. The sector shaft actually slides towards where the top plate is. Be careful of the orientation of the teeth on the sector shaft. There are certian positins where the teeth can bind during dissassembly..
My Myspace
Old 05-21-07, 01:11 PM   #3
what he said
Mace's Avatar
With the Sector shaft removed you can pull the worm drive.
You do not have to get into the heart of the worm drive. It does not have to come apart. You just have to pull it from the actual PS box case. 4 bolts on the face and you are done.
Again, there are seals involved. Be careful when taking things apart.. They might be sticky..
My Myspace
Old 05-21-07, 01:18 PM   #4
what he said
Mace's Avatar
Once you remove the worm drive and the sector shaft all you need to do is clean the tar out of the housing and prep it for drilling/tapping.
The locations are within the TOYODA text and the heel of the housing itself.
My Myspace
Old 05-21-07, 01:25 PM   #5
what he said
Mace's Avatar
Drill out both spots with a 7/16" drill and tap them with a 1/4" NPT pipe tap.
Then CLEAN ALL OF THE METAL SHAVINGS OUT!!
Should not be that hard. But if you do not, you will kill the teflon seals in the box and potentialy mar the worm or the housing.
then it is back to reassembly, I typically use some grease or oil on all of the seals during assembly..
Worm drive goes in, Sector shaft (again be aware of the orientation, there is only a certian amoutn of teeth on the worm gear and the sector shaft, they have to mesh properly), top plate, and pittman arm.
All done.
(BTW, if you have the adjustment procedure for the sector shaft I would love to see the text)
You do want to be aware of how far the threaded portion goes into the heel of the steering box, you do not want it to go much farther than the thickness of the box. Or it can potentialy impact the worm drive.
Box tapped and ready for paint.
I typically run a -6An fitting to 1/4" NPT for my outlets. This allows me to easily hook up the hoses at a later time. Currently I just have the ports plugged off.
I'll upload the rest of the pics later. The board is being cranky..
My Myspace
Old 05-21-07, 01:33 PM   #6
NocalFJ60's Avatar
Good writeup. Can you explain what hydro assist is? It uses a hydraulic ram on the steering to help with big tires? The stock power steering pump have to be modified too?
1982 FJ60
Northern California
TLCA/PMC Member
"He who throws mud only loses ground."
NocalFJ60 is offline   Reply With Quote
Old 05-21-07, 01:48 PM   #7
what he said
Mace's Avatar
Stock PS pump can be modified with the Redneckram.com writeup.
And yes, basicaly you place a hydraulic ram on the tie rod for assist with bigger tires or to make up the difference from lockers.
My Myspace
Old 05-21-07, 01:51 PM   #8
euclid's Avatar
TLCA# 13014
What color are you going to paint it?
Nice writeup, good tech.
Greg Thompson
CottonLand Cruisers
00 Camry: Stock 5SFE - 27 MPG
89 FJ62: OME 2.5, 2" BL, Superior shackles, F250 towers, 315 BFG KM2's on zj80 wheels, Extreme A440, FF,4:88,RDB,longs,ARB front,Lockright rear,Warn XD9K in Rover AL bumper, Kaymar, Wildernes Roofrack, Marlin Sliders, SROR 1/4 sliders.
euclid is offline   Reply With Quote
Old 05-21-07, 01:54 PM   #9
what he said
Mace's Avatar
Ahh the true tech..
Hammerite Black
You could have the box apart, drilled, tapped and back together easily in an hour if you were prepared..
My Myspace
Old 05-21-07, 01:56 PM   #10
euclid's Avatar
TLCA# 13014
I was scared to pull mine appart 2 years ago when it needed a rebuild. West Texas rebuilt and drilled and taped mine for $150, not bad.
Greg Thompson
CottonLand Cruisers
Old 05-21-07, 01:59 PM   #11
NocalFJ60's Avatar
I have an older box I took apart to play around and all the bb's came rolling out. Have to figure out how to put it back together someday and rebuild it.
1982 FJ60
Northern California
TLCA/PMC Member
Old 05-21-07, 02:05 PM   #12
what he said
Mace's Avatar
BB's are easy to deal with.
If you look at this picture you can see that there is a tube that runs between two holes. that tube keeps the BB's flowing around the worm shaft. If you take half of the tube off you can feed the BB's into the valve assembly one at a time. You use the hole that is farthest from the splined section and gently twist the steering shaft allowing the BB's to roll around the worm gear till it is almost filled. Then you put a bit of grease in the other tube allong with the rest of the BB'sand slide them together.
It sounds a hell of a lot more complicated than it really is..
My Myspace
Old 05-21-07, 03:06 PM   #13
brokenparts's Avatar
TLCA# 16127
Good write up Mace...
Old 05-21-07, 03:09 PM   #14
I just had Proffitt do mine. So far, so good. He gave me some little caps so I am isolate the ram, should I ever blow a hydrolic line. Speaking of which, I blew the high pressure line, pump to box, the first day on the trail! Marlin was kind enough to give me a ride into town to grab a new hose. The A/C delco pump is metric on the back, so a stockhose from a toyota T100 pick-up worked great! The steering system is only as good as it's weakest link, in this case it was a 10,000lb ram and 39.5" tires vs. a 20 year old Aisin hose. Hose lost.
have wrench, will travel....
'85 FJ60 ramjet 350, atlas 3.8, NV4500, Dana60s, 39.5" Swampers,hyrdo steer
'08 Tundra 5.7iForce, leveled, with 305s
'06 Audi S4
Winslow is offline   Reply With Quote
Old 05-21-07, 03:29 PM   #15
what he said
Mace's Avatar
lol.
Yep, Toy stuff and Sag thread patterns are identical. Makes life MUCH easier.
I ran the blue aeroquip stuff in my 40. Probably gonna do it in the 60 as well.
My Myspace
Old 05-21-07, 03:33 PM   #16
tclndcrz's Avatar
TLCA# 14430
great info!
this should be in the faq for sure.
-Thomas Crumrine
TLCA #14430
88 FJ62 33x12.5 BFG A/Ts, front parabolics, ARB bumper, warn xd9000, 2badfjs sliders, aussie lockers, longfields, durabak, flowmaster, rear disks...
tclndcrz is offline   Reply With Quote
Old 05-21-07, 03:52 PM   #17
euclid's Avatar
TLCA# 13014
Originally Posted by tclndcrz View Post
great info!
Done. Yall can always PM me to add stuff to the FAQ if you want. I don't always know what the community considers valuable enough for easy FAQ reference.
Greg Thompson
CottonLand Cruisers
Old 05-21-07, 03:54 PM   #18
what he said
Mace's Avatar
You mean I said something that was valuable??
I am gonna call my wife, she aint gonna believe it
My Myspace
Old 05-21-07, 06:56 PM   #19
euclid's Avatar
TLCA# 13014
yep, 1 out of 7344 aint bad!
Greg Thompson
CottonLand Cruisers
Old 07-15-07, 01:50 PM   #20
What's broken now?
green73's Avatar
TLCA# 12222
I took mine apart, not paying attention to this thread. BB's went everywhere. Took a few minutes to figure it all out. It all went back together nicely. I just gotta get lines, a inline cooler, and brackets for the ram. Yeah I am going really slowly with this.
1973 FJ40: SOA, Locked, Caged, etc........... NEVER DONE!
1991 FJ80: Stock.... for a while.
green73 is offline   Reply With Quote
Old 07-15-07, 11:34 PM   #21
TLCA# 16127
Finally got mine all hooked up and on the road... works well so far.
Old 08-27-08, 10:51 AM   #22
what he said
Mace's Avatar
BTW, I just found a source for rebuild kits other than Specter.
Cost is ~ $55.00 shipped. I have one on order, if it works well, I'll be posting up.
My Myspace
Old 08-27-08, 11:17 AM   #23
TLCA# 16127
that's cheap!!! let us know how it goes!
Old 08-27-08, 12:12 PM   #24
sp0rk sp0rk sp0rk!
Spook50's Avatar
Good writeup. Question for anyone who might know, though: Are the PS gearboxes the same between 60s and 62s? I've wanted to do this for quite some time for when I eventually lift my rig and put larger than 31" tires on it.
I wonder if the PS pump mod procedure is the same between both trucks too, now that I think of it...
'88 FJ62 W/ 240K miles, desmogged, stock SUA W/ full length Add-A-Leafs, Tuffy console, TaskLED domelight, Mallory ignition, four wheel discs, Aussie sliding windows
Monniepoo: - Did she smoke with her pussy?
Spook50 is offline   Reply With Quote
Old 08-27-08, 12:27 PM   #25
what he said
Mace's Avatar
There are 2 different bolt patterns on the mounting flange. The internals are the same.
My Myspace
Old 08-27-08, 12:28 PM   #26
euclid's Avatar
TLCA# 13014
I have a redneck ram rebuilt and ported fj60 box on my 62. Bolted up fine.
Greg Thompson
CottonLand Cruisers
