I've been having some persistent electrical problems and could use some simple wiring validation. I have a new battery, starter, alternator, and voltage regulator. The new alternator has be bench tested and was putting out around 14.7 at peak. In the truck, I'm getting an even 12.3v which is constant at idle and under load. I can start and drive fine during the day, but it can't support headlights. I swapped out the external regulator thinking that may be the issue, and the one I got from coolcruisers has different hookups. I'd appreciate if someone could check the wiring here and make sure it is right. F goes the the one input on the regulator, E is grounded, N wasn't hooked up on the last one so I left it alone.
