ZERO Power
Atlanta, Ga
My '91 is lethargic. Absolutely no power at all. At highway speeds its decent, but at lower rpm's its a slug.
I first suspected clogged Catalytic converters but a guy at the muffler shop said that probably wasnt it. He suspected timing.
What direction should i go with this? Ive cleaned the MAF, new air filter and checked the plugs. All looked decent.
You guys have to start giving us some basic information if you really want us to try to answer your questions.
Is this a new condition that you have recently noticed?
Do you have the 3FE engine?
How many miles and what is the recent engine-related maintenance history (other than the MAF cleaning & AF)?
-B-
-B-
Sorry.
1991, 3FE, 174k
I bought the truck in this condition but it also had a tranny problem. The tranny issue was so bad (stuck in O/D) that i didnt notice the lack of power. Now that the tranny is shifting right, the lack of power is evident.
Have you driven another FJ80 with the 3FE? They only have like 120hp so maybe you need to change your expectations.
If you are certain it could be better then get the truck baselined since it is apparently new to you. Fresh tune-up including setting the timing, dizzy cap, rotor, wires, plugs, and whatever else normally done to the 3FE. New fluids in tranny, xfer, engine, and diffs. Check for vacuum leaks while you are doing the tune up.
Common sense stuff really...
-B-
Ive done all the fluids except the diffs. Tranny was flushed by experts. Ive checked the plugs and wires and they look to be in near new condition. Havent checked the cap and rotor... assumed they were as good as the plugs and wires.
I have driven one other 80 and it definitely had more power than mine. One thing that stood out was when i took mine down a little power line trail near my house. While going up a hill the truck felt like it was max'd out... foot was on the floor but it wasnt going to give me any more than it did when the throttle was halfway. for such a capable off-roader i was surprised that it was working so hard on such a small hill.
You mentioned a former tranny problem. Are you positive it is starting out in 1st gear from a stop?
Positive. The tranny is doing great now. Its a little rough when it downshifts sometime, but i know that its downshifting.
Do you remember what year?
93+ have more power!
It was the exact same as mine all the way down to the color.
Is what i described with my very small off-road venture par for the course? If so, maybe i do have too high expectations.
His didnt feel miles ahead of mine, but it did have a clear advantage.
One more point of reference... leaving a light, my wife beat my FJ80 in her 1999 1.3L Metro! Thats just wrong.:D
Looking at the plugs and wires is the same as looking at the outside of a refrigerator and estimating the internal temperature.
Use OEM parts.
If you do a bit of searching you will find boatloads of information on this very issue. The previous posts gave you a good starting point. Sounds like you're new to the 3FE (155 hp BTW). I have never run out of power in low range on mine. I suspect that you were not in low range when climbin this hill.
The FJ80s are great vehicles when in low range. On the highway/freeway it's a totally different story. i'd go 0-60 in like 6 minutes. 3FE pushing 6000+ lbs plus monster will not snap your head back when you floor it. can't really expect much and certainly can't do much.
These trucks were designed in a time where 55 MPH was the norm. Now that most highway traffic travels at 70+ they just aren't geared or powered for it.
Use OEM parts.
I'll change out the plugs, wires, etc. When i say i looked at them i mean i pulled them, inspected them, and decided that they looked very new. It wont hurt to slap some new ones in them, though.
I tried the hill in Hi first and then went back and ran it in low. It acted about the same but low did the job at a higher RPM. Don't get me wrong... it never felt like it was going to come to a stop. It just felt like it was at its peak.
This is my first 3FE. Ive had several toyotas over the past 10 yrs or so, but they were all 22RE's.
Well, i took it to get emissions check done today and it failed. Computer said its burning rich. I did notice it was idling high (750 according to the computer) so i adjusted the idle screw to bring the idle down to around 650.
What else could be making it burn rich? Timing?
When was the last full tune up?
When was the last time the valves were adjusted?
Have the O2 sensors been replaced?
Is the EGR system working properly?
Are the cats original?
Are there holes in the downpipes?
If this truck has an unknown history, then you need to get it back to spec first. You have a lot to do.
fwiw, My 22re mini truck always felt "sportier" than my 3fe beast. Power to weight ratio, 5 speed, etc. The 22re always won when we raced. Different story with the 1fze which leaves the 22re and 3fe in the dust.
