York OBA worklog
NaterGator
On Gilligan's Island
Gainesville, FL
Well, I figured it may be time to detail whats going on with my install.
First and foremost, the parts:
I sourced a york with the proper clutch/pulley from LKQ you-pull for $35 off an old diesel Mercedes. It was dirty as hell pulling the thing, but it looked like it had been serviced before, so I figured it was a good bet. We'll see when I get it running, but the oil is clear and yellowish/red, so at least thats a decent sign. It is a 210R model (the larger displacement) and it pressurizes when I spin the pulley by hand. :D
I got the bracket from Slee and David from GWJ fabbed. It is very sturdy, and I've only had two small issues. The first is that the 10.9 bolts with smaller thread for the rear mounting holes seem to be too long for my head. I don't know if this is a fluke or what... but the second issue is that the smaller/lower mounting hole does not line up properly and thus I cannot use it 'as-is'. If I felt like it was a serious issue I would put the bracket on a drill press and get the hole in the right spot, but it feels sturdy, so I'm not worrying for now. Below is a pic of the trouble spot:
And an overhead view of the compressor pulley vs. the 3 belt pulley. Lineup seems perfect, and by my measurements a 35-36" belt is ideal... otherwise you may contact the high pressure AC line.
I ordered the following stuff from Kilby:
1x Check valve - CV1 - $39.95
1x Pressure switch - PSW1 - $39.95
1x Long Manifold - KE-AM6 - $39.95
1x Safety Valve - SP25 - $7.95
2x hose barb - 272-0604 - $1.55 ea
2x in-out barbs - 272-0606 - $1.96 ea
3x plug - 163-0400 - $1.12 ea
30ft hose - 3/8IG - $1.95 ft
W/ shipping it should be around $320.
Currently I'm thinking about wiring in a regular radioshack toggle switch to control the compressor clutch operation. I'm going to populate a blank switch panel with a toggle switch, a red 5mm power led, and a white 5mm "clutch active" LED to let me know when the clutch has engaged. Also, I hope to tap power from the clutch's power wire to the ECM based on the following from the EWDs for the 96 LX450:
The point of this is to tell the ECM to increase the engine RPMs as if the AC clutch was engaged to allow the york compressor to pressurize the system more quickly. As far as I know nobody else has done this yet, and I'm a bit worried about frying my ECM. I'm not sure what circuit feeds the AC input signal, but I hope the ECM has the necessary internal resistance to allow me to connect the clutch power directly to that lead, or I may be in trouble :D :flipoff2: Any input on this area is appreciated before I go fubar my ECM and need a $3000 replacement from CDan.
I will update when my stuff comes in from Kilby and I can wrap this mofer up.
-----Nate
Maybe once you get it working you can use the compressor to blow all the fairy dust off the engine :hillbilly:
But seriously, your project looks great... i can't imagine how handy it would be when you have it up and running...
About the ECU, i'll have to get back to you on that one... it's late and my eyes are really not trying to look at those diagrams :D
I'm fairly certain my logic about the ECU is correct and that I can simply feed it 12v straight from the battery (or clutch supply wire) without problem, but if for some reason it was fed by an external logic circuit with 10k-ohm resistance, and the resistance in the ECU is very low, I could run into trouble. I suppose I could just test it with my trusty Fluke meter :flipoff2:
Nice project so far.
Rather than spend the time and taking the risk of modifying the ECU inputs to bring the motor back to stock idle speed, you may want to consider investing in a hand throttle instead. You will find that when you start using the York to air up tires you will need to bump up the engine speed to near 2K rpm. Without increasing rpm significantly, it is a slow process, even for the 210. The throttle also allows you to use air tools.
The idea of a hand throttle in my opinion sounds like a good plan...
It does make sense that you would need high rpms in order to provide adequate power to the compressor for air tools, ect...
Sounds safer than risking an ecu?
This doesn't really help as the ECUs are different but I've been thinking about doing the exact same thing on my 3FE to increase idle rpms for more alternator output when my electric fans or aux lights are running. I haven't actually wired it up yet (and may not actually need to as I've got a new custom alternator on the way). However I did confirm that the A/C idle up circuit on the 3FE ECU does just see +12 volts. I did pick up a spare ECU from www.cruiserparts.net for $75 just in case though :D
Rather than trying to feed power to the ECM to idle up the engine when the York clutch is engaged why not feed the York clutch power to a VSV that bypasses the throttle body? I have no 1FZ experience though so I cannot say if the factory used VSV’s for idle up purposes on the 1FZ but they are commonly used by Toyota for this purpose.
Moving forward....
Got the switch and LEDs soldered up and placed in dash blanks. Drilling those switch blanks is a PITA without a drill press, things didn't quite get done perfectly :doh:
The system is going to be as such: I'm using two relays. The first will be set via the manual switch (which is fed by the 12v supply of the cig lighter) and commands a fused 12v lead from the battery to the pressure switch and thus the compressor clutch. A white LED is fed off of the switched power going to the pressure switch. A second relay is also switched automatically by the pressure switch, and triggers +12v sent from the cig lighter power to the ECU's input signal for the AC clutch as well as a red "clutch engaged" LED. This should isolate the ECU from the rest of the components and put it behind a fuse; although I must confess I'm yet to determine if this is going to backfeed the AC clutch and cause it to engage. I need to look into this behavior futher.
All I'm waiting for now is a shipment from Kilby, which I certainly hope will arrive before the weekend when I leave! :doh:
-----Nate
As posted above, use the Aussie OEM Hand Throttle. It will also give you the ability to raise the RPM when winching..
Are you listening? :confused:
HAND THROTTLE!
I can't see any reason to F' with the ECU for something that's running 90% of the time when in use. I use a hand throttle with my YORK OBA.
BTW: Next time, try to source your own parts. Kilby is expensive. I saved $$$ sourcing my own parts. Are you sure you paid $40 for a check valve? I paid $10 for an adjustable Square D pressure switch and $9 for a check valve. The only thing I bought from Kilby were the rubber caps for the QR fittings. Paid $9 for them. I later found them somewhere else for $3.
HAND THROTTLE!
I hear ya'll. I'll get one soon enough :D
I'm beginning to abandon the idea of tapping into the ECU signal lead because I'll have to install diodes to prevent voltage from backfeeding and inadvertently powering the AC clutch. Too much headache :doh:
Well I called kilby today to make sure my order was on it's way since this was the last I had heard from them:
Getting the order to you shouldn't be a problem Nate but you need to clarify
something. You said "long manifold" but you gave the short manifold part number
of KE-AM3. Please clarify and re-send. I'll have Chris get the order out on
Tuesday.
Thanks,
Brad
Kilby Enterprises
As it turns out, nothing had happened and there was no record of any order from my name? :mad: Oh well, looks like I'm heading to work in NC without a working OBA system.
In other news I started the truck up and took it out of the garage after finish the caster bushing replacement only to find I had a very worrying vibration off idle, especially around 2000 rpms. I tracked it down to the york compressor (honestly I thought it was low oil pressure or some other issue, the stumble/off balance feeling was worrying) but I guess it was just not enough belt tension.
I've got it tighter now, but still at revs the engine is appreciable "rougher" than it was before I added the compressor. I'm trying to determine why this is... I can't figure out how to get the belt any tighter, but is a symptom of a belt that is undertensioned that it causes a 'stumble' feeling under revs? That is the only thing I can figure.
Needing some help from those that have crossed this bridge before!
Thanks,
-----Nate
Bump; I still have a bad vibration that makes me uncomfortable leaving the compressor belt on at all if I need to drive the rig.
Can this be a belt tension issue? It happens at higher(ish) RPMs, ~2500 it gets bad and feels like a cylinder is missing or the crankshaft is poorly balanced, but it is in fact something to do with the compressor.
I figured this was supposed to be a pretty uncomplicated setup, but it seems anything but! I'm getting to the point where I may have to ratchet strap the york up from a truss in the ceiling to get enough tension on the belt, and even then I'm not so sure this will fix it :eek:
You mention above that you haven't installed all of the bolts. Missing bolts (particularly toward the rear) would make it more difficult to maintain belt tension, and could be contributing to your vibration.
I haven't made as much progress as you, but I do have my York mounted to the bracket. It's been there for a couple weeks of driving, and it isn't at all noticeable.
I ended up "clearancing" the beveled edge at the top with a cutoff wheel, and opening up a couple of the bolt holes with a slightly larger bit. I did both because the bracket, as shipped, didn't quite sit flush to the head. I also need to do a bit of trimming of the exhaust heat shield -- it impairs the lower rear bolt to the York, when the York is toward the bottom of the slots. NOTE: I have one of the first batch of brackets.
I have the same problems, but it total I cannot fit one bolt at the rear of the bracket-head and one bolt on the lower corner of the compressor.
Both are bolted really solidly onto the engine; I'm working on fixing thse two bolt issues, but I'm not sure if that is it. Have you hooked up a belt yet? That was when my issues started.
No... I need to get the fan-pully replaced first. Probably this weekend or next.
I had no issues with the bolts. Everything went together quite well. My YORK is a bit noisy, especially when running, but nothing annoying.
I haven't done the oil port modification. I'll probably end up digging into it once I see how much oil its spewing.
Kilby sells a kit that includes a coalescing filter and a port so you can return the contents of the filter back into the York. It sounded good the first time I read about it. Someone here on Mud (Jon Held?) pointed out that the coalescing filter captures oil and water and particulates. Probably not the best concoction to be lubing your York with... :eek:
Hants, a word of warning... on your first startup when you rev it a little, the compressor dumps a ton of oil. Be prepared for it and dont let it soak the stuff under your hood like me.
Raven: apparently that mod is a not-so-great one according to Kilby. I may still do it though if oil blowby is high.
Landcrusher, can you take a pic of your compressor looking down at the belt and pulleys? I wonder if this vibration is a function of the V-belt I got from Advance Auto Parts...
