York OBA worklog
Hants said:
Someone here on Mud (Jon Held?) pointed out that the coalescing filter captures oil and water and particulates. Probably not the best concoction to be lubing your York with... :eek:
I'd originally thought of doing this also. Returning collected water from the filter to the compressor is exactly why I ended up NOT doing this. I just have to check the oil level occasionally.
NaterGator said:
Landcrusher, can you take a pic of your compressor looking down at the belt and pulleys? I wonder if this vibration is a function of the V-belt I got from Advance Auto Parts...
I'll do this when I get home tonight. Is your belt not aligned properly? I have a slightly skewed alignment, but it runs and sounds fine. I used the belt Slee provided with the 'kit'.
My belt is 100% perfectly in line which is what makes me so :mad: I feel like I may not be getting enough tension on the belt, but I literally stood one foot on the fender and one on the engine, and tried to pull up on the york as hard as possible while a friend tightened the bolts; now I might have to go to ratchet straps. :doh:
The only other issue is that the milled pulley gets quite close to the AC belt down below, and I believe at high RPMs the two belts may just barely skim each other.
Nater,
Did you complete your install? Any problems with the 210R? I found one at a junk yard, just don't know if it'll work...I need to see if it has the double belt, 6" pulley...
Thanks
