I’ve searched the interwebs, but could not locate the fitting I want. I’m sure it’s out there maybe I’m just not using the correct terms for search.
What I hope to accomplish is placing a “swivable, rotatable”-type fitting between the York 210 compressor & the 90* Wits End fitting.
It would be female threads onto the York.
A connected, in-line, 2-piece part, that the Wits End 90* fitting could attach to.
Fitting would just be a straight piece, no bends.
That will allow the top & bottom to move independently from each other.
Right now the 90* fitting, when tightened, is not in the optimum orientation for running hoses.
If I had a fitting like this, I’d be able to orientate the 90* fitting to exactly where it needs to be after making my connections to the York.
The part I’m describing would attach between the York & 90* fitting below:
