As some of you may know, in the winter of ’99 my truck took a swim in an icy stream. Since that time I have been running with nothing under the carper except for sheet metal, and as I found out yesterday, some rust.
Anyway, I have been pondering the sound/temperature threads here on MUD for a while. I looked at Sully’s thread and that cat has far too much free time on his hands. My goal is not to ride in a Lincoln Towncar, but simply to make the ride a bit more palatable for my old and crusty bones. In the summer the heat from the cats floods into the driver’s footwell, the center console can be used as a smoker, and there are a few melted spots in the carpet under the center row seats from an exhaust leak some time ago. Oh, and the road noise is pretty loud too.
I purchased 6 sheets of McMaster part# 9709T39 after learning about it from another related thread here on MUD. I also joined the forum on secondskin.com and learned that the HeatWave product that I was planning on buying will absorb and hold water. Not a great choice for me…or really anyone who goes in the woods.
Poking around McMaster (I love that place) I found part# 9323K21 which is a flexible bonded fiberglass paper 1/8” thick. This is very easy to work with, doesn’t shed fibers, and is soft. It also has a relatively high R value compared to other products. I bought some 3M spray adhesive at Home Depot to help keep it in place.
I only did the main cabin and did not touch the dashboard. I figure I can do the cargo area if I see the need at anytime without downing the truck.
Pulling the cabin apart took all of an hour including a serious vacuuming job on the carpet after everything was out. 4 seats, center console, seat belt latches, plastic trim, and carpet. Nothing to it.
Found some interesting and undiscovered life forms living below the rear heater duct on the floor and under the center console. Found $0.65 in change. Now I can get that operation I need.
Used the better part of 3 sheets of the dampening material on all the horizontal surfaces, basically adding a layer to the stuff that Tojo used when they made the truck. I ran it as far up the center console as I could, using small strips and rolling into place with a hand roller. Some of it adhered well, some of it not so well. Followed it up with a layer of the fiberglass (used 2 full rolls) and reinstalled the carpet. Took about 4 hours including some cleaning off of the original jute and vacuuming and Simple Green and Windex to get down to a surface that things can stick to. Also touched up the rust with some metal primer while I was there.
Sorry about the lack of pictures. I was working alone on a tight schedule. That’s life. I should be done in a few hours and I’ll take her for a test ride and report back.
