I'm a newbie to this board but not to the 80's as I am now on my 2nd one. I've been lurking (becoming addicted) here for a while but as you can see, only recently registered, and have not posted much yet.....I always seem to find what I need by searching!
Anyway, I recently bought my 2nd 96 FZJ80 only a few months ago. In that time, it has developed a driveline noise that is causing me some concern as it has gotten worse over the 1000 or so miles I've put on the truck since I got it.
I've searched for and read every driveline noise thread I could find here (there are lots), but nothing seems to be exactly like I'm experiencing. Here's the info.....
THE TRUCK: 96 FZJ80, factory lockers, 142K miles. Unfortunately I do not have any history for the truck as I purchased from a dealer, but it is in unusually clean condition for its age and miles and seems like it was well maintained. I say this because I see evidence of lots of new parts all around the truck of varying ages...meaning they all were not just done by the dealer selling it. Examples include motor mounts, shocks, master cylinder. My detective side also tells me that most of the miles were highway because the grille and windshield look almost sandblasted!!
THE NOISE: I have been hearing what I want to say sounds like a bad bearing noise. It's not a whine, it's not a howl, it's not a grinding. If you've ever heard a bearing that was "scored" and on its last leg...that's the sound. It started very faint, but has gotten about twice as loud recently. At first, my wife could not even hear it even when I pointed it out to her. From inside the truck, it sounds like it is coming from the transfer case. The sound is definitely vehicle speed dependant and NOT engine speed dependant. It is most promimant when coasting (no foot on throttle) between 10 and 25 MPH. Faster than that it either goes away, or (more likely) simply can't be heard over tire, wind and road noise. Putting the trans into neutral when coasting at 10 to 25 MPH has NO effect on the noise. Putting the transfer case into neutral when coasting at 10 to 25 MPH makes the noise GO AWAY. It also seems worse when there is LESS load on the drivetrain. By this I mean it is louder when just coasting at a constant speed than it is when using the accelerator to hold the vehicle at a constant speed.
A few other possible clues. As soon as I got the truck I changed all the fluids and what looked like ATF came out of the transfer case. I have read here that this is not that uncommon on these truck from clueless service techs and dealers. Also, I just drained the 80W-90 gear oil that I had put into the transfer case when I changed the fluids and filled it with 85W-140 weight gear oil, as per other threads here, and it DID seem to quiet the noise down significantly but not totally.
I am obviosly thinking transfer case issue here and am fearing the worst. So my questions are.....
1) Any thoughts on the potential source?
2) Can ATF being run in the TC cause significant damage?
3) Should I leave the heavier weight gear oil in there, as it seems to have "helped" somewhat. I put helped in quotes because I know the heavier oil is just masking whatever is really going on in there.
4) Is orange RTV sealant between pieces of the transfer case factory? If not, and I don't think it is, then this transfer case has been opened before.
Thanks!
Thanks!
