I've had no AC for a few years now and it's come time to try and find the culprit.
Last year I put some dye on the system and it showed that my condenser had a leak in it. So that was replaced and myself and a fellow MUD member rigged up a vacuum pump and it seemed to hold vacuum so we charged it and it lasted maybe a week.
This year I felt that maybe taking a stab at it before going to the professionals would be prudent so I "for the hell of it" replaced the O-rings on both the high side hose as well as the low side hose/
This time the system held for a couple of weeks but this wekend it stopped working once again.
So I went out with my goggles and light and still can't find a source for the leak until I removed the dust caps from the quick disconnects at the pump.
With both the hi and Lo caps I heard a distinct pressure release as I unscrewed them.
I've read some where that these valves can be an issue and am looking for some help is replacing them. Any special tools? Do I need to go with factory units? Is there something else I should be checking?
I haven't tried to view the unit within the cab "evaporator?". What's the best way to do this?
