Yet another 3FE overheating thread- plz help!
Hi all-
It’s been ages but happy to see this place is still alive. I picked up a 92 and the 3FE does not enjoy no movement in the South Florida summer so far. Once traffic hits or I get stuck at a drawbridge, the needle starts to climb. Once I start moving again, all is well. Car is fine when it’s not scorching outside or out of direct sunlight parked for long periods of time. Has to be mega hot conditions
What’s been replaced/as it sits:
CSF radiator
Thermostat stuck to open
Clutch fan roaring
Lower hose replaced
Bled system on an incline
I’ve been told “ as long as it’s not in the red you’re fine” by a couple shops but I’m not buying that. Please help me find a way to get this truck right.
Get an infrared heat gun and shut off the engine when taking temp readings. Moving air screws up IR temp readings.
Anyway, when it's showing that it's too hot on the factory gauge, pull over and quickly shut off the engine, take readings on the top and bottom of the radiator, the hoses, the head, the block, etc. Write them down. Do this a few times. You might also consider installing a mechanical (Bourdon tube) temperature gauge in the head, if you really want to know what the temps are. Factory gauges are crap, pretty much across the board.
Since your issue is in slow-moving traffic, are you sure you have the correct fan and fan clutch, and shroud? My 3FE FJ62 reads hotter than I'd like (interestingly on the highway), but the actual engine temps are not out of range. CSF radiators have been blamed for slightly hotter running temps in the FJ60/2 world, too.
You may never get a 'middle of the factory temp gauge' reading, but you owe it to yourself to find out what the actual temps are.
Weak/improper fan clutch. Should be an Aisin FCT-049 with an aqua/green hub. There are many many threads regarding adding thicker silicone oil and adjusting port opening temperature for better cooling. There are other items that MUST be in place for proper cooling.
fan clutch, get a Aisin green hub, drain the fluid and add 20k in it.
FWIW, CSF radiator runs about 10 degree hotter compared to my all alum. unit, so take that into consideration.
Thanks guys, just getting back to this. A “specialist” here added the Asian green hub a while back and a new Toyota tstat. I will verify what weight he used. It’s still overheating on the gauge to just before the red marker
Some more notes to add- if I simply pop the hood, temps go back to normal and it can stay like that all day. This is pretty frustrating. If you guys have any other items to check, I’m all ears. I’ll read the thread posted as well
Clutch fan roaring
Fan is pushing a lot of air, still overheating until the hood is up - your radiator isn’t super gunked up is it?
Maybe a bit of a long shot but I would take some temp readings of your exhaust pipes and see if your catalytic converter might be clogged. I’m a 1FZ guy, not familiar with 3FEs at all but clogged cats can do weird things to the 1FZ. Good luck!
That make zero sense. If you need to pop hood so your engine does not overheat, you are having some major issues. My 3FE will take a good 15-20 mins for the engine to warm up and if i just let it idle, it will stay @ 180F all day. You have a blocked coolant passage or your thermostat is stuck close would be my guess...
Radiator is a brand new CSF and thermostat is brand new. Aisin green hub is brand new, it’s all brand new besides the water pump. If it starts to tick up, the remedy is a little movement to get some airflow on the grill or simply pop the hood. Completely baffled
Well there is your problem....CSF runs about 15 degree hotter than factory or the alum. radiator. Get rid of the CSF and go with an alum. and problem solved. I did that 8 yrs ago, replaced with a CSF and about a month later, it was in the dumpster....
