I have an unfortunate OCD trait that has me getting a little carried away with my FJ40 restoration. I decided to give Caswell's Copy-Cad electroplating system a try to see if I could duplicate the original finish on some of the hardware for aesthetic and corrosion resistance reasons. I've been plating various parts to figure out the system and get the desired results and overall I am very happy with the purchase. It takes several tries to get it right but here is the set-up and some of the results:
Power supply
Plating solutions
Bolt in the plating solution
A bunch of nuts strung up for plating with bead separators - this system did not work well - the beads centered the nuts preventing contact with the wire. Calculations of surface area to determine correct amperage are on the underlying paper.
Here are some yellow cadmium plated cone washers (I know they are not really visible but I'm using them to work out technique).
Some more yellow cad parts
Here are the yellow zinc parts. I'm really happy with the way these have been turning out.
Previous posts had mixed reviews of the Caswell system but I'm pretty happy with what I'm getting and would recommend it if you are into this sort of thing.
Power supply
Plating solutions
