x
I know for sure it would work in the front, I just replaced my rockers and it is definetly a possibility. The only issue I would see is coming out in the back. I'm not entirely sure how you would do that. I went and looked at mine and it seems you may have to pop up front under the rear wheel well. Not sure if that is something you would want to do.
Let us know what you come up with as I would also like my wires out of the way.
Feasible & it sounds like a good way to hide it, but I would want full access to my wiring loom for future inspections. I'd cut a hole in the floor, just past the front body mount, & run it along the underside of the body, next to the rocker. I know there are some underbody ribs that go to the rockers. I'd go thru them & use grommets. Route it up the rear wheelwell & inside the fenderwell.
